Transmission Brake...on 65 IIA
  • swray
    • Nov 2007
    • 16
    I removed the rear plate and found all internal parts soaked in Transmission Oil. I see there is an oil catcher and a joint washer for the oil catcher. Are there other points of ingress, and pointers of how to stop the oil-bath after replacing the brake shoes? Also, the springs were rattling around disconnected. From the rear of the vehicle looking forward, do they go on the inside or outside of the brake shoes? What a mess!
    Steven Wray
    Fishersville, VA
    1965 IIA
    1958 TR3A
  • siii8873
    • 1013
    there is an oil seal on the output shaft also, inside of the mud shield.
    THING 1 - 1973 88 SIII - SOLD
    THING 5 - 1958 109 PU
    THING 6 - 1954 86" HT
    • gudjeon
      • 613
      I may be saying something you already know, but make sure you set up the expander to "float" as per the manual. I have seen many a PO tighten this right up and this mechanism can't centre itself resulting in a chuddering set up if applied on the move. Oh, that and it don't work too good.
