Is it reasonably straight forward to switch in a 200 Tdi into a series III 88? If not how much extra work is there to do it. I have the trany and transfere case out of the defender if needed.
1970 Series III 88 engine swap 200Tdi
1968 Series IIA
1987 D90 Kid's project
German wirehair Pointer (Wood Hound)Tags: None -
It is a very straightforward swap, you can use your existing transmission if desired, but if its not in good shape the tdi will eat it up and you'll find yourself replacing gears. There is a full write up on TeriAnn's website http://www.expeditionlandrover.info/...rsionIntro.htm
Good luck and post updates!
-Rob------------------------------------------------
72 SIII 88
67 SIIA 109
82 SIII Stage 1 V8
-- http://www.youtube.com/barnfind88 -- -
Swapping the motor in itself is not terribly difficult if you have the right motor ie; Defender unit with the high turbo, which will basicly bolt together. The difficulty is in the small details and getting a good result with the radiator intercooler set-up which requires considerable fabrication (and I am not a big fan of electric fans) and creativity. IMO it is generally these things that make the difference between good and poor conversions.
The Defender trans and t-case is a little long for an 88 with the motor in original location. It could be used if you want to put a Defender or stage I front grill in it.Comment
I may be looking at this as well, my motor overheated pretty badly this past weekend and I wont be able to survey the damage until May. I'm just thinking whether to keep it original or to upgrade... Would I need to add any extra gauges or could I retain the classic look of my IIa dash and how much would it cost to put a 200 Tdi in?WAR EAGLE!
65 IIa 88
95 RRC 25th Anniversary
98 Discovery LE7
00 DII (Sold)Comment
non-turbo 200's run around 3k. Add turbo and rebuilt and they can get up to 8k fast if you have to have it shipped.
And defender 200tdis are a rarity as all the UK guys are already using them or looking for them. So you may have to buy new 300tdi manifolds ect...
Do the math and the $$$/performance over a nicely built 2.25? not much at all.Comment
Well after reading up, I think I would rather just keep the 2.25 and save the 300 Tdi for the future 110... Hopefully once I take apart the 2.25 in my truck it wont be too bad, but it did start tapping pretty bad before I could get it to the shoulder so I'm not hopeful. I may start looking for a good 8:1 ratio 2.25 over the next couple of months... Any good sources?WAR EAGLE!
65 IIa 88
98 Discovery LE7
Sounds like a bent push rod and a stuck lifter.
www.singingcamel.comComment
Yeah, the one you have. Most likely can shave the head to 8:1. Talk to a good machine shop.Comment
I am still thinking of doing this the 200tdi is out of a defender and comes with the trany and transfere case hich I wont be using so they will be for sale. I like diesel better than gas but that is just my opinion as you know everyone has one. The 2.25 is in good running condition if anyone needs one.1968 Series IIA
German wirehair Pointer (Wood Hound)Comment
