How much UHMW?
  • albersj51
    • May 2010
    • 687
    How much UHMW?
    Im tearing apart each leaf spring so I can rehab them (originals). While ive heard mixed reviews on using UHMW-PE tape, I'm going to move forward with adding it to my springs.
    The question is, how much of it will I need? McMaster-Carr has an 18yrd/54 ft roll. These are stock springs. Is one roll enough, or will I need 2? Given the price of the stuff I dont want to buy more than I need.
    Thanks!
  • siii8873
    • 1013
    use a tape measure to determie this. Measure the length of the springs.
    THING 1 - 1973 88 SIII - SOLD
    THING 5 - 1958 109 PU
    THING 6 - 1954 86" HT
    • alaskajosh
      • Sep 2007
      • 208
      I'm not sure how thick you're intending to use but I'd suggest erring to the thicker options. I worked exhaustively and meticulously cleaning up my springs and applying the UHMW tape of the thickness spec'd on a popular website and it lasted about a week. I could post pictures of the sad shreds that remain hanging from between the leaves. It didn't unstick, it just wore through and flaked out.
      They ride nicely to this day but I credit that to the job I did cleaning them up and also because I've since kept them oily.
      Good luck
      • mongoswede
        • May 2010
        • 757
        I pulled apart my springs, removed all the rust and scale, and then painted each leaf with Black POR-15. The POR is very flexible and durable and slippery. I reassembled and remounted the packs and they move! I was going to put a strip of high pressure assembly lube down the center of each leaf prior to assembly but I didnt have it handy and was eager to put things back together.
        • meatblanket
          • Dec 2007
          • 98
          Here's a suggestion if you want to do this the "right" way.
          Alcan Spring in Grand Junction CO uses Delrin pads and "diamond cut" leaves.
          If you could get some of those pads, you'd be set. Of course, that means you'd have to drill holes in your springs to install them, which is easier said than done.
          Take a look here:
          Alcan Spring builds the finest custom leaf spring suspension on the planet! Built American strong with American steel. We can customize any vehicle. Call us!
          FWIW I have a set of Alcans on my Jeep, and they work VERY well.
          '55 SI 86
          • alaskajosh
            • Sep 2007
            • 208
            Alcan Spring in Grand Junction CO...
            Those look sweet!
            I've always wondered why there aren't more/better options for Series LRs. For example OME had a good thing going with some of their leaf spring offerings but never targeted the leafsprung LRs.
            Why doesn't someone have something like these available, off the shelf, for LRs??
            • yorker
              • 1635
              I think the market simply isn't big enough. It is already saturated with parabolic springs for those who don't like the standard springs. Alcan will make LR springs to order to your specs for you if you want. I don't know anyone who has taken them up on it though.
              Land Rover UK Forums
              • albersj51
                • May 2010
                • 687
                Whats going on, mike?
                I called them and asked...they can send the disks but said drilling the spring is nearly impossible without the right tools.
                The product sounds great! Said they can make them for my rover based on factory specs. The price if high, but not much higher than parabolics...somewhere near $900-$1000; not including shipping. If I were looking for paras, I would seriously reconsider and look at their product.
                Mike-you mentioned The "right" way... And josh's didn't last long...got another option? I'm open to other ideas...but based on my reading, the best way is with UHMW.
                • ducttape
                  • 175
                  If I recall my sales pitch from the mill, UHMW is a non-friction surfaced film that is typically used in non heat applications. However, it does not provide much abrasion resistance. It is used to line assembly line shuts, etc, which stuff just needs to slide downhill.
                  Teflon is also made reinforced with fiberglass and the typical application is the other end of heat seal bars, etc.
                  I would think the flexing of the springs would wear through the UHMW non reinforced film fairly quickly, leaving you with not much more than the bill you paid for it.
                  1967 Series IIA 88
                  • alaskajosh
                    • Sep 2007
                    • 208
                    Originally posted by ducttape
                    ..it does not provide much abrasion resistance.
                    Exactly.
                    I can't speak to the heat end of things but I can see the abrasion problem clearly. In my case I live on a gravel road with puddles and by the time some water-borne grit splashed over the leaves the UHMW wore through QUICKLY and the remaining scraps started falling out here and there.. shredded and embedded with grit.
                    I harp on this issue every chance I get only because as long as this idea circulates I hope to save others the intense labor and trouble.
                    • albersj51
                      • May 2010
                      • 687
                      Is there another, better option? 2 rolls is over $100...so, if I can save that im happy to do so! I've read about graphite paint...any feedback? Or, am I trying to achieve something that I can't? I've got the packs open and painted in masterseries (like POR-15), so the labor is done so I can clean and paint them.
                      • TeriAnn
                        • 1087
                        Originally posted by alaskajosh
                        Exactly.
                        And you know the funny thing is that I've had sheets of UHMV between my leaf springs since 1997 an the stuff i still there doing its thing. It has been through a lot of different trails during those years.
                        Mine is from a roll of the material given to me by a friend and not tape so does not have adhesive on one side. The ends have slid a little to the sides at the ends of the leafs and are a little brittle but otherwise 14 years later they are there doing their thing.
                        Looking at the web page I'm pretty sure I either made a typo with the thickness or in measuring. I'm pretty sure mine are a lot thicker than stated on the web page.
                        I need to go back and remeasure. It probably would not hurt to go back to the person who gave me the roll to see if he can remember where he got it.
                        I apologize for the thickness goof.
                        • LaneRover
                          • 1743
                          Even Nasa gets Measurements wrong some times!
                          • meatblanket
                            • Dec 2007
                            • 98
                            Jason, I've no other ideas for you-- sounds like TeriAnn's held up well, so you might give it a shot.
                            My SI came with a set of RM parabolics on it already, and the front is sagging a bit. Someday they'll get replaced with a set of Alcans. The front end of a Series LR is pretty handicapped already by the short spring, you really need all the flex you can get out of them.
                            '55 SI 86
                            • albersj51
                              • May 2010
                              • 687
                              I found delrin spring liners, but they only got to 2 1/4, the rovers are 2 1/2.
