This truck was a diesel, the diesel block was bad, and I found a 5 main gas and put it in. the bellhousing, trans and transfer case are the same one that was in it. Besides, all the mounts lineup. I do have the stock length straps. Any body know the length of the extended ones for the parabolics? Our host only showed the stock ones and the spring kit did not come with any.
The shocks don't look like they are right, installed they are just about fully compressed. It seems that when you hit a big enough hole, bump, etc, they will bottom out when the wheel moves up??
I'm still working on the driveshaft issue. Probably just going to have one built by the measurments. I guess this is what you get into when you buy a disassembled truck.
