Some updates:
Decided to rebuild the old 2.25l petrol instead of convert to diesel. Since I was keeping it, I am rebuilding it. New 20-over AE/Nural pistons, bearings, 2.5 cam, new oil pump, new radiator, etc. Just got everything back from the machine shop (rebored 20 over, crank polished and balanced, flywheel turned and balanced, head decked slightly, new valve seals, 3-angle valve job, new crankshaft bushing, new conrod bushings, all new timing components, dist drive gear, waterpump, etc).
I have to take the block to another shop with a line hone to get the cam bearings installed, which should be done next week. With any luck, the motor will be back together by the end of next weekend.
Here are some pics of the machined parts, excluding the block.
