Series III front hub issues flipping into 4x4...
  • gzarembo
    • Sep 2009
    • 19
    I can't flip the front hubs unless I'm on pavement and its rolling..if I try any other time I can only lock one so I end up freeing them both, rolling just on the rear.
    any thoughts?
    88 -1972 Series III
    Live Free or Die
  • SalemRover
    • Aug 2007
    • 310
    The pic is great, but I really have a hard time picturing someone trying to flip hubs on a moving vehicle. Do you have a video? This would be immensely helpful.
    -Jason
    • siii8873
      • 1013
      are you engaging the 4wd before trying to put the hubs in? Works much easier if you first engage the hubs and then place in 4WD. When disengaging put vehicle in 2wd then disengage. Sometimes you need to back up a little first.
      THING 1 - 1973 88 SIII - SOLD
      THING 5 - 1958 109 PU
      THING 6 - 1954 86" HT
      • JackIIA
        • Dec 2008
        • 498
        -Jason
        Not to mention entertaining!
        1970 88 IIA
        • LaneRover
          • 1743
          any thoughts?
          I find that if the hubs are sticking a bit just rocking the Rover back and forth a little bit moves things around enough for it to either lock or unlock.
          • I Leak Oil
            • 1796
            Lanes advice is solid. What hubs do you have? Sometimes the drill center left on the outer half shaft can contact the hub keeping it from turning freely. If you remove the outer hub, file down the end of the half shaft a little, it frees it up quite a bit.
