SIII 1973. I was driving to work yesterday, downshifted and could not engage third...all other gears work fine, but it will not shift into third. I drained the oil out of the mainbox through a paper filter and felt around inside the drain hole. No bits of gear or synchro clips that i could find or see there.
Has anyone experienced this abrupt loss of a gear.
Much appreciate suggestions...thank you. Clive
Minor point but just for the record if this is the only problem you have you could save quite a bit of disassembly by NOT pulling the entire gearbox out of the car.
