how do i remove my steering wheel?
  • Triumphdaytona2007
    • Aug 2010
    • 87
    hey! i am putting a good bulkhead on my series 2a and im trying to remove the steering wheel but cant get it to budge, it is the wire spoked type, ive taken the bolt out of it but cant get it to come off the splines, can the column be removed from the gear box or is there a trick to removing the steering wheel, also how do i take off the metal ring under the wheel i didnt see any screws holding it on, i recently took the wheel off a series 3 and it just slid off no problem so im stumped
    1964 Series IIa 109" Pick-Up RHD
    1965 Series IIa 88" Wagon LHD
    1968 Series IIa 109" Station Wagon LHD
  • albersj51
    • May 2010
    • 687
    My steering wheel is different (later IIA), but I just remove the horn cover, undid the nut and it pulled right out.
    • LaneRover
      • 1743
      Isn't there also a 'cinch bolt' on the side? in addition to the bolt in the center under the horn button?
        • Aug 2010
        • 87
        on mine i dont have a bolt under the horn cover only a cinch bolt on the side, its un-done but still wont budge
        • LaneRover
          • 1743
          i remember having to move mine back and forth right left right left right left etc . . .
          You pried off the horn button assembly and there is no nut? hhmmm I remember a nut being in there. But my memory has failed me before!
          • albersj51
            • May 2010
            • 687
            Under the horn and before or after the nut is a lock washer and you have to bend the tabs down.
            • CMorris
              • 66
              Daytona,
              As you know there is no bolt under your horn button, just a splined shaft. On these old banjo type wheels there is just the pinch bolt at the base of the hub securing the wheel. I've run into this before and had luck using PB Blaster and VERY careful heat (Mapp gass or Oxy/Acet.) on the top of the shaft only. Try not to do any prying of the slit at the base of the hub.....I've seen a few of these old wheels destroyed by folks in this situation resorting to pry bars for quick removal. Patience and elbow grease are what it will take.............just like every other job on a Series truck.
              Good luck.
                I've had no issues using a large flat head screwdriver as a wedge. Wedge it into the relief slit and pull the wheel. Just go easy with it and you won't damage anything and you'll still make it easy on yourself getting it off. The biggest mistake people make is they don't remove the pinch bolt. They loosen it thinking the wheel will come off.
                • LaneRover
                  • 1743
                  Told ya my memory is spotty!
                  I like the screw driver idea
                  • Sputnicker
                    • May 2009
                    • 105
                    Definitely have to completely remove the pinch bolt. Penetrating fluid, wedging the crack, heat and judicious whacking with a rubber hammer are all good ideas.
                      • Aug 2010
                      • 87
                      awesome i will try that tonite, i got the pb blaster ready, im trying to keep it in the best shape i can, the wheel is in bad shape now but i hope to have it fixed up by a shop in town, it has a collar under the wheel, is that attached with anything? i couldnt get it to come off, on my series 3 the collar was attached with 2 screws
                        • 400
                        The collar is held in place by two screws, accessible from inside the collar once you remove the steering wheel....
                          • Aug 2010
                          • 87
                          ok great just makin sure they come off together thanks
                          • Terrys
                            • May 2007
                            • 1382
                            Besides the spline there is a small taper, which is often hard to break. I Sit in the drivers seat, and put my knees on the back side of the steering wheel giving a little pressure, one hand on the top of the wheel applying some rearward pressure, and give the column a smack with a brass (soft) hammer. It almost always pops off with one smack. A smack is a little more than a tap, but less than a whack.
                            • mrdoiron
                              • Dec 2009
                              • 446
                              I like reading this Terry, kinda like soft core.... lol
                              1961 Ser IIa Hybrid Defender
                              1969 Ser IIa Bugeye
                              1998 Disco - ex wife :-(
                              2010 RR Sport Supercharged
                              http://mikerovers.shutterfly.com/
