radiator housing paint
  • siii8873
    • 1013
    what would the recommended paint be for doing the radiator tanks, support. Most spray cans are for up to 200 degF a little low. Of course there is the high temp stuff but did not see any high temp primers at store?
    THING 1 - 1973 88 SIII - SOLD
    THING 5 - 1958 109 PU
    THING 6 - 1954 86" HT
  • siiirhd88
    • 400
    I've just used regular, not high heat spray paint on the rad, t stat housing and other bits. For black paint I generally use the Krylon brand of semi-flat as it is easy to find and dries quickly.
    '02 Disco II SD
    '80 SIII 109
    '75 SIII 88 V8
    '68 SIIA 109 V8
    • jac04
      • 1884
      I have painted the radiators (and radiator supports) on most of my restoration projects with regular spray paint (Tru-Test enamel paint from True Value, ) with no issues at all. IIRC, I used Eastwood Rust Encapsulator on my Lightweight because I had some left over. I have tried the Eastwood Radiator Paint and I did not like it at all. It did not cover well and flaked off very easily.
      • yorker
        • 1635
        Regular enamel will be fine.
        Land Rover UK Forums
        • shawn88
          • Jul 2010
          • 19
          I just picked up some Krylon radiator paint. I plan on painting mine on Saturday, hope it turns out okay.
