1970 IIa 109 ex mod build thread
  • Broadstone
    • Jan 2009
    • 216
    #31
    Originally posted by
    To do the 'quote thingy', instead of hitting 'reply', hit 'quote'. Then if you only want to quote a small bit, delete the rest, just leaving the bracketed (the parts inside the [ and
    symbols) parts
    You learn something new every day. Thanks Terrys!
    1973 NADA 88
    • scatterling
      • 183
      #32
      Build looks great!
      Neil Hanekom
      '73 LHD 88
      '99 D1
      • I Leak Oil
        • 1796
        #33
        Looks good and you work quick. All that in a day huh?
        Not to hijack but any info on the flattie? Looks like USN issue?
        • stonefox
          • Jul 2010
          • 450
          #34
          Originally posted by jac04
          Powdercoated brake lines! Wow! I thought that I was going overboard by clear coating mine.
          Yes Jeff you definately cut some corners on your lightweight , I was gunna call you out on it but I'm glad you came clean to all of us about it.
          Mason, I truly am having second thoughts about starting my build thread.You have raised the bar . I know the hours and coin I have put into my project and it pales in comparison to your build. Each new entry makes my jaw drop.
          You must be divorced by now
          Sean
          1963 88'' IIa daily driver
          1970 88"
          1971 88"
          authenticstoneworks.com
          • masonater
            • Nov 2007
            • 329
            #35
            47 CJ3A restored about 8 or 9 years ago. It is my wiring inspiration, all done like an airplane with brakers and very simple. Not military just painted like one. Only has about 350 miles since rebuild about 300 of which i put on last spring...Runs amazing, pretty much a hangar queen sadly. I do cruise it around the airport a lot though...
            1970 Series IIA 109 EX-MOD
            1971 Series IIA 109 EX-MOD
            1982 Mercedes 300TD
            1989 RRC
            1993 D110
            1994 RRC LWB
            1995 RRC LWB
            1995 RRC LWB
            1995 Disco
            1996 GMC 2500 Suburban
            1996 Disco
            1997 Disco
            2001 RR P38
            2005 LR3 HSE
            2006 RR HSE
            • masonater
              • Nov 2007
              • 329
              #36
              try 26 and single! I figure i have about 2,000 hours into the build so far and probably close to that in $$ give or take a few hundred. Helps to have access to a mega shop and a seasonal job, although that doesn't really help with cash flow. Eat. Sleep. Rover.
              1982 Mercedes 300TD
              1989 RRC
              1993 D110
              1994 RRC LWB
              1995 RRC LWB
              1995 RRC LWB
              1995 Disco
              1996 Disco
              1997 Disco
              2001 RR P38
              2005 LR3 HSE
              2006 RR HSE
              • masonater
                • Nov 2007
                • 329
                #37
                Before a huge thunderstorm passed through today i had the bulkhead outside. Lots of sanding and grinding away a combination of surface rust and layers of paint and undercoat. Glad i took it down to metal because i found some sneaky rust around the door posts. I will probably just fill in the holes with weld. Found lots of bondo around the seams on the front side. Wonder who did that? doubt the military folks took the time to seam seal with bondo...
                1982 Mercedes 300TD
                1989 RRC
                1993 D110
                1994 RRC LWB
                1995 RRC LWB
                1995 RRC LWB
                1995 Disco
                1996 Disco
                1997 Disco
                2001 RR P38
                2005 LR3 HSE
                2006 RR HSE
                • jac04
                  • 1884
                  #38
                  I found dried-out seam sealer on almost all my bulkhead seams. It was so dried-out that it looked like Bondo. It was definitely doing more harm than good. After sandblasting, I slightly thinned some Eastwood Rust Encapsulator and poured it into all the seams.
                  try 26 and single! I figure i have about 2,000 hours into the build so far ...
                  Wow, reminds me of the good old days! Must be nice to work during daylight hours. All my work gets done between 8pm and about 1am when my wife and 2 kids are sleeping.
                  • rbbailey
                    • Sep 2010
                    • 161
                    #39
                    RV-4, Citabria, Pacer, a Skymaster, something sporty under the cloth... oh, and a Series 109. .......I could live in that hangar and be happy for the rest of my life. So. Cool.
                    • masonater
                      • Nov 2007
                      • 329
                      #40
                      RV-8 with a 540, 240z under the cover, and i live up in the loft
                      1982 Mercedes 300TD
                      1989 RRC
                      1993 D110
                      1994 RRC LWB
                      1995 RRC LWB
                      1995 RRC LWB
                      1995 Disco
                      1996 Disco
                      1997 Disco
                      2001 RR P38
                      2005 LR3 HSE
                      2006 RR HSE
                      • rbbailey
                        • Sep 2010
                        • 161
                        #41
                        Too... much.... to.... comprehend. What a collection!
                        I'm just hoping to get my IIa up and running some day. The Pacer is actually the plane I want to buy -- but each of those birds would be on my short list, although to fill it out, I'd have to add a Cessna 180 and probably a Maule.
                        • TSR53
                          • Mar 2006
                          • 733
                          #42
                          Exceptional build thread, very nice shop hanger too! We like your powder coated brake lines. Very nice to have your loft right off the tarmac, lucky you - test the 240Z and all the other goodies.
                          Since you gurus are straying off-topic I might as well chime in... Great to see all the pilots come out the wood work. Getting ready for flying season soon with piloting my electric powered RC Sailplanes. My hanger is filled with a 2 meter and several 2.35+ meter planes; Radian, DG-1000, ASK-21, Ventus and a Discus.
                          Cheers, Thompson
                          Rovers North, Inc.
                          • masonater
                            • Nov 2007
                            • 329
                            #43
                            went away for a week back home to pick up some BFG muds 255/85/16 i scored for free. Hope they fit
                            Pressure washed the hood and the old crappy paint job just flaked right off.
                            Hung the bulkhead, radiator support, and seat box and got them ready to start painting
                            Used some aircraft etch primer called dupont variprime 615s, after some research it appears that you have to prime over this primer. I had already ordered some etching primer from eastwood but couldn't wait to start.
                            I had only one quart of eastwoods primer and ran out after the bulkhead and radiator support.
                            Filled a couple holes in the tailgate and sanded it ready for primer.
                            Sanded the hood to try and smooth out the 4 layers of old paint.
                            1982 Mercedes 300TD
                            1989 RRC
                            1993 D110
                            1994 RRC LWB
                            1995 RRC LWB
                            1995 RRC LWB
                            1995 Disco
                            1996 Disco
                            1997 Disco
                            2001 RR P38
                            2005 LR3 HSE
                            2006 RR HSE
                            • rwollschlager
                              • Sep 2007
                              • 583
                              #44
                              those should fit fine, if you suddenly decide you don't like them shoot me a pm and I will gladly purchase them from you.
                              keep up the great work!
                              -Rob
                              72 SIII 88
                              67 SIIA 109
                              82 SIII Stage 1 V8
                              • masonater
                                • Nov 2007
                                • 329
                                #45
                                Got the sills apart and sanded them down good enough for a primer.
                                After a battle with the 20 something flathead screws and nuts holding the spare tire plate on the hood, i used a cut off wheel and zipped them all off. All those layers of paint and rust was making it next to impossible to get a good bite with a flat head.
                                1982 Mercedes 300TD
                                1989 RRC
                                1993 D110
                                1994 RRC LWB
                                1995 RRC LWB
                                1995 RRC LWB
                                1995 Disco
                                1996 Disco
                                1997 Disco
                                2001 RR P38
                                2005 LR3 HSE
                                2006 RR HSE
