1970 IIa 109 ex mod build thread
  • masonater
    • Nov 2007
    • 329
    #46
    tornado sirens going off now so i figure i'd update my build thread in case this is it. Today i finished sanding and prepping the doors for paint along with a few smaller bits.
    Also used some sticky screen stuff then bondo to patch the missing corners of my doors. Not a fan of bondo but someday ill get new ones so it will do for now.
    1970 Series IIA 109 EX-MOD
    1971 Series IIA 109 EX-MOD
    1982 Mercedes 300TD
    1989 RRC
    1993 D110
    1994 RRC LWB
    1995 RRC LWB
    1995 RRC LWB
    1995 Disco
    1996 GMC 2500 Suburban
    1996 Disco
    1997 Disco
    2001 RR P38
    2005 LR3 HSE
    2006 RR HSE
    • masonater
      • Nov 2007
      • 329
      #47
      my misson for tomorrow is to prime all these parts along with the hood and 5 wheels. Bulkhead, radiator grill, and seat box are already primed. If i can, im going to shoot all the parts in desert tan by the end of the day.
      1982 Mercedes 300TD
      1989 RRC
      1993 D110
      1994 RRC LWB
      1995 RRC LWB
      1995 RRC LWB
      1995 Disco
      1996 Disco
      1997 Disco
      2001 RR P38
      2005 LR3 HSE
      2006 RR HSE
      • morgant
        • Jun 2009
        • 170
        #48
        I'd just POR-15 over it. It'll seal it against rust nicely, add some strength, and you'll still have plenty of drainage. Although, you'd probably want to prep the surface underneath it first and I'm assuming the sticky screen stuff is mostly aluminum, so I'm not sure how well the POR-15 would adhere to it.
        Regardless, I'm with you that you can just plan for new doors. Considering the rest of your build quality, I think you can skimp on door corners a bit.
        May the tornados pass your hangar by.
        rikuwoiku — to travel overland.
        2002 Discovery II SE
        SeriesParts.com — A master list of parts, part suppliers (our gracious hosts included), and repair shops for Series Land Rovers.
        • jac04
          • 1884
          #49
          I can't wait to see how they come out. Keep up the good work.
          • cousindave
            • Jan 2007
            • 192
            #50
            I ABSOLUTELY love this post! Good luck! Keep the posts coming. I am addicted!
            • masonater
              • Nov 2007
              • 329
              #51
              Thanks guys! I am so excited to finally be doing things that are near the end. UPS has my primer on the truck for delivery. Here is a shot of post bondo and sanding of the doors. Came out pretty good considering the corners did not exist.
              1982 Mercedes 300TD
              1989 RRC
              1993 D110
              1994 RRC LWB
              1995 RRC LWB
              1995 RRC LWB
              1995 Disco
              1996 Disco
              1997 Disco
              2001 RR P38
              2005 LR3 HSE
              2006 RR HSE
              • masonater
                • Nov 2007
                • 329
                #52
                Huge day of painting today. 28 parts i think at last count. All done in eastwoods self etching primer, with the exception of the seat box that was done in dupont variprime 615s and 620s converter (wanted to try it). I used a Croix HVLP system that has painted many airplanes in its day and it worked pretty well. Aside from auto shop in high school this was my first try at painting car parts. I think i went a little too heavy on the primer because i used the about 3/4 of a gallon on all this stuff. I wanted to get into top coating with tan today, but after 6 hours of priming I needed a break. UPS didn't show up with the primer until about 4pm which set me back.
                Before primer
                After
                This was round 3 or 4 of parts
                Also did a little powder coating while waiting for the primer. I managed to score some desert tan a while back and i think its almost a dead match to the paint i have.
                1982 Mercedes 300TD
                1989 RRC
                1993 D110
                1994 RRC LWB
                1995 RRC LWB
                1995 RRC LWB
                1995 Disco
                1996 Disco
                1997 Disco
                2001 RR P38
                2005 LR3 HSE
                2006 RR HSE
                • masonater
                  • Nov 2007
                  • 329
                  #53
                  Awesome day today, finally painted a bunch of parts desert tan. Spent about 8 hours spraying 3 or 4 coats on most all of the parts. I didn't get as good of a coat as i would have liked on 2 of the wheels so tomorrow i will reshoot them. After all that time spraying, my goggles got pretty covered in paint and i guess i just couldn't see well enough to notice. In the end i was pretty happy with how it came out considering this was my first time. I also realized that after ordering 4 gallons of paint and only using 3/4 of one today, i will have lots left over. Maybe ill paint my grand cherokee too!
                  1982 Mercedes 300TD
                  1989 RRC
                  1993 D110
                  1994 RRC LWB
                  1995 RRC LWB
                  1995 RRC LWB
                  1995 Disco
                  1996 Disco
                  1997 Disco
                  2001 RR P38
                  2005 LR3 HSE
                  2006 RR HSE
                  • rejeep
                    • Apr 2010
                    • 420
                    #54
                    Sweet
                    1971 SIIa 88" NAS Dauntles V6
                    1974 SIII 109" RHD
                    • jac04
                      • 1884
                      #55
                      Looks great Mason! You're really moving on this project.
                      • masonater
                        • Nov 2007
                        • 329
                        #56
                        Thanks Jeff, I had already started painted before i got your PM. I put 3 or 4 coats on wheels already but I think im going to try a sling like you did and shoot one or 2 more. I have plenty of paint thats for sure! Should I wait a while after they dry before mounting them on rubber? I was thinking a day or 2?
                        1982 Mercedes 300TD
                        1989 RRC
                        1993 D110
                        1994 RRC LWB
                        1995 RRC LWB
                        1995 RRC LWB
                        1995 Disco
                        1996 Disco
                        1997 Disco
                        2001 RR P38
                        2005 LR3 HSE
                        2006 RR HSE
                        • martindktm
                          • Jun 2008
                          • 218
                          #57
                          What kind of paint are you using?
                          • jac04
                            • 1884
                            #58
                            I waited a little over a week, but I wanted to be really sure that they were dry. I was worried that the rubber would 'pull' the paint off when the tires were mounted.
                            • masonater
                              • Nov 2007
                              • 329
                              #59
                              Enamel from Rapco Parts. Seems to dry pretty quick. Im itching to get this thing rolling!
                              1982 Mercedes 300TD
                              1989 RRC
                              1993 D110
                              1994 RRC LWB
                              1995 RRC LWB
                              1995 RRC LWB
                              1995 Disco
                              1996 Disco
                              1997 Disco
                              2001 RR P38
                              2005 LR3 HSE
                              2006 RR HSE
                              • martindktm
                                • Jun 2008
                                • 218
                                #60
                                Is it a spray can or you are using a spray gun?
