Fuse Ratings
  • Cutter
    • Feb 2009
    • 455
    Fuse Ratings
    I assumed it would be listed in the green bible but I can't find it- can someone tell me the ratings of the fuses in the SIII fuse panel? One of mine is burned out, but one the PO replaced with a circuit breaker (his way of dealing with a short in the headlamps that I resolved) that constantly gets knocked out by my knee. There's no markings on it to get a rating. I also want to double check the ratings on them all just to know whats what.
  • Cutter
    • Feb 2009
    • 455
    Ok I found it, section 86-3 for anyone that needs it- it says all should be 35 amp...yeah so none of mine are
    Glad I checked.
      Those aren't your normal 35 amp fuses that you pick up at Advance Auto. Hopefully TeriAnn will chime in as she knows how to explain this quite well.
      I'll try to dig up the old post where it was explained...
      • Cutter
        • Feb 2009
        • 455
        Thanks for the heads up, I already bought some- I'll head back and get the proper ones. The chart is on her site here: http://www.expeditionlandrover.info/fuses.html
          Here it is:
