I cut off the worm gear at the bottom of the shaft. The shaft is very hard so you can't turn it to a common diameter. As such, I ground it best I could and sleeved it with a 3/4" OD piece of pipe and welded it on both ends. The 3/4" OD is common for Borgeson universal joints. I used their joints on both ends and a "double-D" slip joint in the middle. Good guys there at Borgeson.
P38 power steering conversion ??
I see what you did! Looking at your pics, you slide the OD tube over the bottom 6" or so of the inner column, welded it to the column, then slid the u-joint over the OD tube then put the outter column back over it? Did you weld the u-joint to the OD tube to hold it in place or is it snug enough and the tension from the intermediate shaft holds it in place?
If thats the case, I can probably do it myself.Comment
I welded it to the sleeve. The intermediate shaft needs to be a two-piece shaft that will collapse in the event of an accident. This is very important. Yes, I know that a Series truck isn't the safest thing in the world but there's no need in turning the steering column into a jousting stick aimed at your face. Some sort of slip shaft needs to go there. I use a "double-D" shaft from Borgeson.
I machined and installed a bronze bushing in the bottom of the column that rides on that sleeve as well. That's what that zerk fitting is for. The sleeve was notched for a heavy snap-ring and washer that rides on the bottom side of this bushing. This allows you to put a little pre-load on the top bearing that keeps the steering shaft stable in the outer column.Comment
you dont need to sleeve it, the rover shaft is hollow so you can buy 36 spline 3/4 shafting, turn it down to fit inside of the rover column and weld it. At that point its all bolt together.
Ike, that's the exact part I said I was going to question you about!
You guys will have to forgive my dumb questions, this is my first conversion of anything...heck, my first resto! The goal is to learn and do as much as possible myself! Keep in mind I have zero fab knowledge/skills, but willing to learn.
Ike, I havent pulled the column from the box yet, but the top of your end piece looks like where the column enters the standard box,.is this correct? Where did you get the spline shaft and the other half of the end cap? Did you use a bearing and if so, where did you get it?
Thanks,
jasonComment
-yes thats the stock mounting flange on the original column
-36x3/4 splined shafting is available from borgeson
-the other half is a bearing retainer with an integral mounting flange - I made it.
-I used a sealed bearing I obtained from a local bearing house.
Hope that helpsComment
Thanks, Ike! Sounds like a visit to the machine shop is in order!.
Based on everything, the FJ60 seems like the way to go. No need to re-ream the pitman arm or cut it shorter, LR TREs work. The new drag link and column bearing are the same for all conversions.
Thanks guysComment
If you mean the Scout box then Autozone sell an overhaul kit for $29. Pump is just a generic GM spam can.
Here's the PS set up I did which takes a little from many of the previous posters. Shaft was modified by Ike as described. Joints and slip joint are Borgeson. The mounted bearing came from McMaster Carr and I made up the bracket from metal stock. It uses the upper outer column with no mods and keeps the steering wheel in the exact position it had with the original system. It also uses the original steering box mounts and is VERY strong.
Thanks, Greenmeanie!
So you got the column bearing from mcmaster? Would you happen to have a PN? That's exactly what Im missing! I can get the intermediate shaft/u-joints from borgeson and make the drag link from DOM tubing, taping it for LR TREs, but the column is what hangs me up. If there is a pre-made bushing that I can bolt to modified column, then im in business.Comment
I don't have the number at hand. The McMaster catalogue is pretty easy to workl with though. You want a mounted bearing with a 3/4" ID and the smallest square flange available. IIRC I had to slot the mounting holes in the flange slightly to match the bolt pattern on the flange at the base of the outer column. I think one of the Toyota vendors (Inchworm maybe?) sels this part already modified.Comment
Make sure you find a set of 11/16X16 left and right handed taps or weld in inserts for the drag link. Everything I could find was 11/16X18. There may be a few guys on here that have themThanks, Greenmeanie!
