my work space - delayed
  • kwd509
    • Aug 2010
    • 190
    The barn I'd been hoping to use for the rover repair is on hold as the property changes hands. It may be available but not until fall at the earliest. Still, about 18 inches of snow (on mud) left but soon I should begin rover work in ernest. If I build a pole barn that is that much less $ for the rover itself (though it would be nice). If I can manage with a simple moveable greeenhouse or tent-garage I lay out less $ now and hopefully have the bulk of the work done by fall, even at my slow pace. And, wife actually approves of a greenhouse as a leftover from the project.
    I've seen photos of rovers being worked-on in very minimal accommodations. I would imagine jacks/stands would rest on sturdy steel plate (1'x1') to add stability.
    But my question is whether there Are complications I am not anticipating (as opposed to simple inconvenience)?
    Thanks.
  • LaneRover
    • 1743
    I'd say go for the greenhouse to make the wife happy!
    For the short term you could probably get away with plywood squares under the jackstands. I would make sure you could rig up a light and can you get power out there for tools too?
    • kwd509
      • Aug 2010
      • 190
      Light and power and water are readily available......so that looks good.
      • albersj51
        • May 2010
        • 687
        I'm doing my restoration in a greenhouse and it works great! Problem here is now that its getting to 85+ degrees it feels like 100+!
        • printjunky
          • 325
          An enclosed Rover workspace? What, what? Fancy, that.
          • LaneRover
            • 1743
            Ya but he's in VT. He'll be lucky if it feels like 85.
            • kwd509
              • Aug 2010
              • 190
              85f would feel like Texas in august..... But if greenhouse works then no complaints..... I will have to lay claim to the limited flat ground.
              • JackIIA
                • Dec 2008
                • 498
                kw - why not pour a pad while you're at it. I've done that when doing mason work (e.g., large pads for sizable entry steps, walks.)
                granted, your talking 3 pallets of concrete, and digging to avoid frost heaves, lay sand, etc. but renting a mixer is cheap and bags around here go for $3.14. If you're building anything permanent, it might be worth it. a greenhouse sounds like it to me. and that gets around worrying about plywood, steel sheeting, mud, etc. of course, it is back breaking work too. but i think worth it.
                1970 88 IIA
