Transfer Case High is gone
  • ShootingCar
    • Jan 2008
    • 60
    I was driving my '69 Series IIa 88 home tonight, when as I was going up a hill, I heard a loud bang and suddenly no drive train. I coasted back down and started trying to shift the transfer case shifter. It would drive in low range but when shifting to high range it appeared to just be in neutral. I ended up having to drive it home 5 miles or so in low range. It was singing but I got home going up to 20 mph with fifth gear. What have I done and how do you recommend I fix it? Remember I am all thumbs with this stuff and this is my first major breakdown.
    Jeff
    Jeff Pearl
    1969 SIIa 88 ECR Coil Spring Conversion
    North Central AZ
  • Alk-3
    • Mar 2009
    • 185
    first thing id do is take off the bottom cover, and see whats up. maybe a good idea to strain the oil when you drain it to see whats in the oil.
    i just recently replaced my transfer case with a rebuilt unit from rovers down south. its a big job to do, but i managed it in a weekend by myself pretty easily.. it was outside in the winter too, which made working on it a pain, but it was still a pretty straight forward task. thats your worst case scenario anyway, so its not that bad.
    • leafsprung
      • 1008
      Unlikely its the t-case. probably broken rear axle. Try it in 4wd high see if it goes.
      • LaneRover
        • 1743
        I agree with Ike's take on this, at least check it out.
        • Terrys
          • May 2007
          • 1382
          X2 on the broken axle.
          • ShootingCar
            • Jan 2008
            • 60
            It's a broken axle
            Wow Ike, you know how to pick em. I tried it in 4wd high and it ran fine in the driveway. So it must be a broken axle. So when you are in low range is it always in 4wd then that it would run in low range?
            Thanks for the direction everyone. Wow the power of the internet.
            Jeff
            Jeff Pearl
            North Central AZ
            • TeriAnn
              • 1087
              It is the big bang theory. Hear a big bang, loose the connection between the engine & wheels, it is the rear axle breaking.
              Most rear axles are good for about 45K miles, less if you take a 109 off road.
              Replace both axles and if the broken axle broke on the inside, remove the diff and clean well to get any chips out. If you just replace one, the other will break before too long. The cure of course is to replace with a 24 spline upgrade. Or just replace both with new 10 spline ones every 40K miles before they break.
              • kwd509
                • Aug 2010
                • 181
                And for an 88?
                Just curious......lifespan of axles the same for 88's?.
                • KelseyM
                  • Oct 2007
                  • 89
                  Yep, I blew my rear 10 spline going around a turn at 10mph a few months ago
                  Kelsey M
                  1989 Range Rover Classic
                  1971 Series 2A 88"
                  • ShootingCar
                    • Jan 2008
                    • 60
                    where do all of the axles come from
                    My truck actually has Range Rover axles on it from the coil conversion from ECR years ago.
                    I looked for replacement axles for my truck. RN only had one used right side and one new left side and said that per Land Rover in the UK, the right side was no longer available. Atlantic British had only one new right and left, which is where I got them both from.
                    So if all of us are breaking these axles all the time, then where are we going to get them from? Do you guys carry spares with you?
                    thanks for all your help.
                    Jeff
                    Jeff Pearl
                    North Central AZ
                    • TeriAnn
                      • 1087
                      After breaking seven 10 spline rear axles over the years I converted my 109 over to the much stronger Salisbury 24 spline rear axle assembly (stock set up for SIII 109s). To which I added the stronger ARB diff, stronger Great basin axles and drive flanges. This was 14 years ago. Haven't broken anything back there since.
                      After breaking one front axle & twisting a second My front is converted to the stronger 24 spline SeriesTrek front axles and stronger 24 spline Truetrac diff.
                      I gave up on 10 spline Rover axles and the weak Rover diffs.
                      • lrdukdog
                        • 321
                        axles
                        Ok, here's what I did to mine.....flame suit on Mr. Bond,
                        got this tip/idea from a friend a NASA
                        Jim Wolf
                        • Terrys
                          • May 2007
                          • 1382
                          WTF? I bought my first series truck 40 years ago next month. I've lost count of how many I've had, but pushing 3 dozen, and I have yet to break an axle shaft. I bought a spare R&L 25 years ago, but so far, haven't even taken them out of the cardboard tubes. What am I doing wrong?
                          • stonefox
                            • Jul 2010
                            • 450
                            Terry,
                            How do you expect the part suppliers to stay in business with you pussy footin' around with your axles for the last forty years. They have mouthes to feed too you know.
                            Sean
                            1963 88'' IIa daily driver
                            1970 88"
                            1971 88"
                            authenticstoneworks.com
                            • JimCT
                              • 518
                              rear axles
                              1968 ambulance/camper, broke standard axle, replaced with Salisbury, broke one of those, got Great Basin axles, years and nothing broken. Detroit locker in rear now, still nothing busted.
                              1963 Unimog Radio box
                              1995 LWB RR
