I changed out the slave cylinder on a series 11a due to leaking, Its on a 109.
new slave cylinder in place, 2 pumps on the pedal and its rock hard? pedal will not move.
Release the pressure by bleeding and a couple pumps and damn its hard..
Thinking maybe its a fallty slave cylinder ,changed that out , same thing.
Linkage thru the bell housing is good, (worked good before the leak.)
I did'nt change the adjusting rod but did'nt think I had too. Worked well with the leak.
i'm now thinking it maybe a faulty master clutch , What do you guys think ? or if any of you had this similar problem I would appreciate some direction ..Thanks
www.singingcamel.com
