Hello all,
While doing my first oil change this weekend, I pulled the sump and filter housing, cleaned them, sanded and painted them black, and reinstalled them with a new sump gasket and filter oring seal. One set of leaks gone!
I noticed oil-definitely oil and not brake fluid as the brake fluid hasn't dropped at all in over 3K miles-on the inside of the tires. Appeared to be coming from the swivel ball hub seals.
I did some research, and found TeriAnn's helpful page on replacing the hub seal by making a small cut. Anyone done it this way?
I also found a thread stating that oftentimes a vent or breather is clogged, and allowing oil to be pushed past what are good hub seals.
Could not find mention of these breathers in the WSM. Anyone got a pic of where these are, and how to remove/clean them? And any pics on the vent tubes that some are suggesting retrofitting?
I have new hub seals ready to go, and will approach it via Teri's advice unless someone else comments, but would rather not if all it needs are these vents cleaning out!
One leak at a time......
Julian
Julian
