Well due to having a shoulder surgery and the subsequent recovery and being busy running my business I have not made as much progress to date on my Series III, 2.25 109" three door as I would like but slowly I am getting things accomplished (finally got two side panel windows installed) but I am running into an issue that has me stumped and I really need some help.
My Rover runs just fine for awhile (approximately 10 to 15 miles) and then it begins to stutter, loose power, "throb" ( for lack of a better adjective), stalls out and then simply dies. It seems to start again reasonably well if I wait a few minutes, almost as though something is overheating and causing it to stall out or something.
It is a very troublesome and worrisome problem, as tonight my Rover it sitting on the side of the road about 10 miles from my home waiting for me to figure out the issue and correct it, as I could not coax it any further than that.
This has been an issue since I started actually trying to drive it starting in about February of this year (after I was able to get working on it after my shoulder had recovered enough from surgery to actually turn a tool) and this is the second time I have had this very same issue.
After the first time this occurred, I purchased and replaced the plugs, wires, distributor cap and condensor and was hoping that had fixed this issue (though I am still not sure exactly what the problem is) but apparently those new parts did not fix the problem, unfortunately.
Tonight is ran just fine for again, about 10 to 12 miles, and then as I was beginning to go up a long hill toward home (I have had the Rover at a friends shop for the last six weeks or so as that is where I installed the side windows and then I have been out of town for three weeks due to business) the stuttering and lagging began again and within 300 feet it had stalled out.
I would sincerely appreciate any and/or all help, thoughts, ideas or suggestions you all might have as to what is causing this issue and how I might be able to fix it. I have a new ignition coil that I plan to install tomorrow but I am fresh out of ideas and sure need some help.
Thanks in advance,
Mbogo
P.S. As a simple disclaimer, I am pretty new to Rovers and am not what I would call a great mechanic by any stretch of the imagination but I am trying hard to learn and have been enjoying the process.
*NOTE: Updated, as of 05/17/11, and moved the "updates" to this original first post/page
n page two of this thread*
Friday Afternoon, May 14th:So I installed the new ignition coil and, trying to learn and follow recommendations you have all mentioned about fixing one thing / altering one variable at a time, started it up and it ran for just a few minutes and stalled out - this while parked!
So I then searched and searched and searched for a second fuel filter and unless I am totally blind I could not, for the life of me, find any other fuel filter except for the glass sediment bowl/filter (again this is on a 2.25 gas, 4 cyl. engine). I had ordered a new replacement fuel filter, and an inline fuel filter, from RoversNorth but from my inspection and looking at the manuals I can't see where there is a place for the fuel filter element they sent me - I followed the gas line from the rear fuel tank all the way to the sediment bowl/filter and the only thing I could find was the sediment bowl.
Realizing I was A) searching for something that didn't exist or B) Totally as blind as a bat and didn't realize it I removed the sediment bowl, cleaned it thoroughly, as well as the wire/mesh milter and the gasket and reinstalled them.
I primed the fuel pump manually and started it up and it purred along just fine for 10 minutes.
At that point it was getting late at my "roadside garage" and I needed to head home for the night.
Saturday, May 15th:With high expectations, based upon the engines purr from the night before, I had my wife and kids drop me off at the pull-out my Rover has been guarding the last two nights.
She started right up and off I went, heading up the long hill towards home ...... I made it about a mile before the stuttering and stall came.
I coasted back to my "roadside garage" and waited for my wife's return so she could tow me home where, though my knowledge is no keener I at least have more tools and a better place to work!
Testing an idea out in our driveway, I let the Rover idle for 45 minutes, which it did without a hiccup - no stalling or any problems at all !!
So, to a degree I am back where I started but am wondering if the degree of incline is a contributing factor? Could going uphill bring a new diagnosis to anyones mind? Could it be and if so, how or why?
I will, to the best of my ability, keep going through each of the suggestions you have all posted, to try to find the answer but welcome and refinement or others ideas you might have.
UPDATED: Tuesday, May 17th:
As I have found time I have been tinkering with this problem and ordering some parts.
Today I took off the old rear fuel tank (which did have a small leak in it and I had plannned to replace even before this issue developed) and the most interesting discovery was all the junk that was in the end of the draw tube, where the fuel line screwed into the elbow of the draw tube. Frankly, if that debris had/has been there the whole time it's suprising that my Rover ran at all.
I am not convinced that the draw tube was the whole cause of this problem and I won't know until I have fully installed the new fuel tank and put everything back together and given it a test but that is where I am now, working on installing the new fuel tank (still waiting on a few parts, such as the fuel sender, etc...) I have a question regarding the new fuel tank put will post that question in a new thread so as not to confuse myself lol
UPDATED: May 26, 2011:
Here is a link to my post on these forums with an update:
Thanks in advance,
Mbogo
n page two of this thread*Friday Afternoon, May 14th:So I installed the new ignition coil and, trying to learn and follow recommendations you have all mentioned about fixing one thing / altering one variable at a time, started it up and it ran for just a few minutes and stalled out - this while parked!
