I am putting the tunnel and floor back together,(PO took it apart) .
I know there is a little retainer that slides down the lever and the spring seats on that. However I am not sure how far down the rod the retainer should go, at the moment it slides down to the threaded section. and on initial assemble it seems that there was not enough tension on the spring.
I suspect that the retainer should not go beyond the last bend on the rod. If this is right, how can this retainer be kept in the correct place.(what is the correct place?)
I didnt find answers in my search.
( I know it is a simple problem, however I am not sure how much tension should be on the spring).
Thanks in advance..
Thanks in advance..
