Starter Problem
  • BobJones
    • Jun 2008
    • 61
    Starter Problem
    Hey Folks, it's been a while but I'm back to work on the beast (59 SERII 88)
    I was able to start it three times yesterday without a problem, but on the forth try it was dead. There was no clicks or whirls or sounds of any sort.
    Battery is good, switch is good, and the starter is grounded, but no sign of life. I'm thinking that the starter is dead, it is original.
    Could I be missing something?
    Also, how many cranking amps do you folks suggests for a battery for these things? And mine is still positive earth.
    Have you cleaned the battery contacts and the battery-to-chassis/engine contact area?
    Have you checked the wires to the starter solenoid? Mine sometimes corrode off at the connector to the solenoid.
    • Triumphdaytona2007
      • Aug 2010
      • 87
      mine did the same thing but it turned out the terminal had come loose from the cable at the starter, you could wiggle it and it would start but it finally quit altogether and had to re-crimp the terminal
      1964 Series IIa 109" Pick-Up RHD
      1965 Series IIa 88" Wagon LHD
      1968 Series IIa 109" Station Wagon LHD
      • cousindave
        • Jan 2007
        • 192
        I have the same issue but when the vehicle is hot. I replaced all grounds, ignition, solenoid, battery it did help alot, not as prevalent. I know I'm missing something but I also know I am also getting closer. I did find the sheathing to the brush wires worn out inside the starter. I taped it and that seemed to be the world of difference. good luck
        • Terrys
          • May 2007
          • 1382
          If all your cable junctions look good, investigate the condition of the starter commutator and brush slides. These can get corrosion preventing the brushes from making firm contact with the commutator. A good firm contact keeps the commutator clean, but if the brushes hang, the contact will first start arcing, then glaze the commutator segments. Best way to clean up the commutator is in a lathe with a fine flat file, but if you don't have access to a lathe, wrap it with some fine sandpaper (not emory paper) and give it a few twists. Make sure the gaps between the segments are clean
          • siii8873
            • 1013
            I had an intermittant starter problem which ended up being a worn commutator. It had developed a shallow depression where the brushes ran. I think the brushes would rid up on the side not giving good contact. I carefully renewed the commutator with fine sandpaper, cleaned everything with a dielectric cleaner and it worked great ever since.
            THING 1 - 1973 88 SIII - SOLD
            THING 5 - 1958 109 PU
            THING 6 - 1954 86" HT
            • BobJones
              • Jun 2008
              • 61
              Thanks for the advice. I opened it up and it is really worn. I'm replacing with a refurb unit and will fix up the old one keeping as a spare.
