I'm trying to understand what my options are for axles, hopefully somebody here can shed some light. I currently have a standard front, and what appears to be a military or HD rear of some kind. It's not a Salisbury, it looks like the front axle with some heavy box section welded along the bottom of the axle tubes.
At a minimum, I'd be pulling them both apart and rebuilding everything. I'd like to put airlockers in while everything is apart. So the real question is, should I be putting 24 spline axles in while I'm at it? The ARB carrier for the standard Rover diff appears to be 10 spline, so would I have to retrofit it for 24 splines, or can you use the 24 spline Sals carrier in the Rover diff? Is it really even worth it? The value of the lockers would be to let me crawl over tricky stuff instead of using momentum and brute force, and that would seem to then put less stress on the 10 spline shafts. I also have this idea that I'd rather snap a halfshaft in a bad situation than break the diff itself or something further up the line, but then again what I'd really rather is to not break anything at all
. Or is offroading not even the issue, and I should be worrying more about snapping something while accelerating away on dry pavement with everything open?
Sorry for the run on questions - this is just the one part of the project I haven't really wrapped my head around yet.
. Or is offroading not even the issue, and I should be worrying more about snapping something while accelerating away on dry pavement with everything open?Sorry for the run on questions - this is just the one part of the project I haven't really wrapped my head around yet.
