I ordered a set of poly bushings for my 109, and so far have pulled one of the springs. The PO said he replaced all the bushings with poly but one wheel, which is the one I started on. He did this when he installed parabolics. I would not be surprised to find no poly anywhere else either just because I can't see it on visual inspection. My question is if it is worthwhile to replace the bushings on the parabolic springs since they are fairly new (10 years max) with poly or just leave as is since I'm going to be at war with the chassis bushings long enough.
Edit: Yeah, I'm leaving those right where they are otherwise all summer will go by while I swap these. Dead end post.
