I replaced suspension bushings, and have a few questions. On a short test drive things seem good, but I want to double check things.
First Question- I swapped my back springs (parabolics) to try to correct a tilt in the truck (success). I didn't follow the bible's instructions for setting the spring height in the rear prior to tightening the shackles- Easy enough to go back and do that now, my question is the dimension listed in the procedure for the 109 the same with parabolics?
Second question- I have a question on the front shackle orientation- the outer shackle has a small offset on one side of one hole. The inner has a larger spacer that faces the spring, and I assumed that the outer also faces the spring? Just looking for confirmation, I'm fairly certain it does but want to double check. My concern is my steering stops seem to need adjustment, and I'm not sure why.
Thanks!
Thanks!
