I have finally tracked down the source of my brake problems, Its the booster unit..(I think). I removed the M/C from the booster, when ever the engine is started the booster push rod is extended. It appears that the control valve is not allowing equalizing vacuum. to the rear of the diaphragm. therefore keeping the M/C depressed.
Has any one ever repaired these boosters, or what are the replacement alternatives..
