After the filter adapter leak was all good and fixed today I figured while I was dirty I would swap out the cap and rotor and check the points and plugs..
Whatever cheap wire set I threw on the truck last time was all cracked and broken by the boots..
Like an idiot I figured it must have been like that for a while and should make no a difference..
Started the motor and it fired right up ran for about 30 seconds after a few revs and died...
Engine cranks strong, but doesn't catch now..
I noticed the coil was hot, real hot.. Other than that all appears to be normal.. No smoke or anything...
In all likelihood did I fry the coil? I couldn't see a resistor in the engine compartment..
