Exhaust studs
  • SeriesShorty
    • Sep 2008
    • 275
    Exhaust studs
    Everytime I have to undo the downpipe from the exhaust manifold, the most rearward stud always comes out. The first time it happened I removed the manifold and took it to a machine shop to get a it cleaned up and get all new studs in.
    When I removed the downpipe a few months ago to work on my gearbox, low and behold that damn rear stud came out again. I haven't mastered getting the perfect angle when undoing the bolt so it binds up just enough to yank the stud out.
    I have no interest in removing the manifold again to put a new stud in. Any suggestions on how to get a new one back in and how to keep the damn thing in???
    Thanks!
  • luckyjoe
    • 335
    I'd say if the stud pulls out and doesn't break-off, you are well ahead in the game! Seriously though, generously lube it up with anti-seize and double-nut it back in...
    Tom P.
    1965 exMoD 109
    1995 RRC LWB w/EAS
    • scatterling
      • 183
      PM sent.
      Neil Hanekom
      '73 LHD 88
      '75 FFR 109 exMOD Build Photo's
      '99 D1
      • JimCT
        • 518
        Brass nuts
        Use brass nuts on the studs so they release and not the stud
        1963 Unimog Radio box
        1995 LWB RR
          I wholehartedly concur with the use of brass nuts on the manifold and downpipe fixings. They're not too expensive and are available at every decent auto parts store. You'll be glad you did!
          • luckyjoe
            • 335
            Originally posted by SafeAirOne
            I wholehartedly concur with the use of brass nuts...
            Me too!!! I also double nut them and this seems to prevent the single nut from loosening...
            Tom P.
            1965 exMoD 109
            1995 RRC LWB w/EAS
              Hadn't had any loosening issues using brass nuts and steel lock washers (and that's on my shaking, rattle-y 2.5 diesel).
              • Donnie
                • 287
                Thanks!
                I agree with brass nut's....also use never seize, & double nut or triple nut if U have to.
                The first nut needs to be tightened to specs..........the other 1 or 2 nuts just protect the threads from rusting..All this doesn't matter if U R using stainless studs,,
                • SeriesShorty
                  • Sep 2008
                  • 275
                  Well crap, the manifold is gonna have to come off. I put the new stud back in and gently reinstalled my brass nuts. Within 2 minutes of the engine idling, it literally shat the entire stud out onto the pavement.
                  But at least the gearbox is in and it moved under it's own power.
                    • 400
                    In a pinch I have run a longer bolt thru the manifold stud hole and attached a nut and washer on the top side to hold it in place. If you get the right bolt you could even use your brass nut for easier removal....
                    • scatterling
                      • 183
                      exhausts are way overrated anyway The most important thing is that your truck moved!! Congrats!
                      Neil Hanekom
                      '73 LHD 88
                      '99 D1
                      • JimCT
                        • 518
                        heli-coil
                        drop the exhaust and install heli-coils
                        1995 LWB RR
