Gents,
I had the turn signals stop working on my 69 bug-eye.
Can't believe this has never failed on me up until now frankly...as pretty much everything else has !
After a brief call with our host site expects at RN, I got it down to the bi-metallic relay/can. Found 2 of them behind the dash, one for 4 way, and the other for the indicator...as the 4 way flashers did continue to work fine. So I switched them so my indicators work until I get a replacement - figured a little more important for the signal flashers than 4-way ...
When talking to the RN gents, I realized something I wasn't aware of, when he asked me if the small light at the base of the turn signal arm (in the cast housing) flashes when I turn the indicator arm - to which I responded - what light ? I hadn't even realized there was a light there, as it hadn't ever worked since I got the vehicle, I never even noticed the small circular window...which was also nicely gummed up with dirt anyway, to me it looked like a small recessed screw hole.
In fact, not having a dash light to remind me that I left the bloody indicator on half the day (to the dismay of many behind me), I had wired the indicator wires into my 4 way flasher light last year just to get a visual inside the vehicle that the turn signal is still on...
Soooo, much wiser now, I need to go get another 2-prong buss flasher relay, AND also need to find one these very small bulbs that mounts in the turn signal arm housing...the bulb says on it "12v 2-2W" it appears.
Anyone know if that is hard to find anywhere ??
thanks, mike
thanks, mike
