Hello all,
So after being stranded with a dead battery today, moved right along in the Series III and noticed when I pushed the brake pedal a loud hissing sound.
It seems to brake fine, but whenever I press the pedal, hissing sounds.
At home, I ran the engine with a piece of wood lodged against the brake pedal to obtain pressure and the hissing sound. I see no evidence of a leak at the brake booster.....but how should I tell?
-The 90 degree elbow is tight with no play
-Maybe the hose needs replacing (will get some 3/8 hose tomorrow)
-I checked the allen screw that plugs the hole in the brake booster---nice and tight
Is there anything else to check? The brake booster and master cylinder were all replaced new in 2008, about 7000 miles ago (prev owner/looked at receipts). I would hope they last longer than that, but anything else???
Cheers,
Julian
Cheers,
Julian
) then you might get a hiss (although probably lack of pressure as well).
