I think they were mintex? RN sells one for 29/set and I think these were 39/set or may 39/49.
New problem! I put on SS hose front and rear and just finished bleeding the brakes and The pedal goes to the floor and stops VERY slowly. I adjusted all the pedal travel when I put on the shoes. I had to replace the LHF rigid line which is done and did not touch the cylinders or shoes or adjusted them. I simply changed the freaking flex lines! While bleeding I feel the pedal build pressure and release but when we are finished the pedal hits the floor and the rover SLOWLY comes to a stop. I changed the fluid to Castrol synthetic and have completely bled the old fluid out. It has been about 4-6 weeks since I did that. Will the change damage my rubber seals that quickly? No leaks anywhere just a lack of pressure. Could it be the MC. Fluid is going down when we bleed. Do I need to recheck adjustment on shoes x 4? Pumping the pedal doesnt help much, it use to before I found my leaking rear cylinders I would have to pump the brakes every now and then to get a better grab on the brakes but no more than once and she was slowing down quick. Getting extremely frustrated with this as I have not been able to drive it around for 2-3 months.
Thanks,
Mark
Thanks,
Mark
