hey! my alternator went out yesterday on my rover, i have two rovers for parts but they are positive earth, my rover is a 64 2.25L gas negative earth, the junk rovers are 68ish 2.25L gas pos earth, can i just take the generator off the positive earth and put on the negative earth engine? if so can i just run the charging wires straight to the battery? the previous owner has a homemade wiring harness so im trying not to tap into it
can i put a positive earth generator on negative earth engine?
1964 Series IIa 109" Pick-Up RHD
1965 Series IIa 88" Wagon LHD
1968 Series IIa 109" Station Wagon LHDTags: None -
You can run the generator, but you will need to flash the field to convert it to produce electricity in a negative earth setting. If the rover you are taking the generator from has been sitting for a while, you may need to flash the field coil anyway. Teri-Ann has a section on her site on how to convert to Negative earth, and it should cover how to do it on there. http://www.expeditionlandrover.info/...Conversion.htmBad gas mileage gets you to some of the greatest places on earth. -
awesome! sounds very easy to do thanks! imma go try it now1964 Series IIa 109" Pick-Up RHD
1968 Series IIa 109" Station Wagon LHDComment
