Coupla questions: Seems to be unanimous on the fiber head gasket. Any alternate opinions?
And I know I'm opening the long debated OEM/Aftermarket can of worms, but a Cam timing gear from Allmakes is about $13, and from LR it's about $130! I have little doubt that the LR gear is superior, but holy catfish! Ten times superior? Sorry, that doesn't seem very likely.
This seems to go for everything I'm looking at. I've seen OEM cam prices of up to, (and over) $1,000! (Apparently these are NOs as the part is NLA - so a different story, I understand).
But an aftermarket cam comes in around $160.
Here's the list so far of what I KNOW I'm going to need (engine's not out yet, so this will certainly get longer):
Cam (2.5)
Timing cover gasket
Front oil seal
Top gear
Top gear bolt
Top gear bolt locker
Water jacket gasket
Oil fill gasket
Rear main seal and cork "t's"
Oil pan gasket
Freeze plug
Hylomar
Am I missing something? (probably)
Any opinion on OEM/Aftermarket on any of those specifically.
Also, any advice on other good things to perform or look for while doing this (pull engine, pull head? I will obviously be doing things like inspecting the head/valves, etc, but if there's something that EVERYONE says I should just do while it's out, I'd take it under serious advisement. Though unless there is obvious damage I will not dig into the head or pistons/crank at all. My goal is to be back on the road by Aug. 1.
Cam (2.5)
Timing cover gasket
Front oil seal
Top gear
Top gear bolt
Water jacket gasket
Oil fill gasket
Oil pan gasket
Freeze plug
Hylomar
