Any reason I should not use bolt on engine mounts on this boxed frame?
Bolt-on vs. Weld-on Engine Mounts
I assume for engine conversion. Sleeve the mounting holes if you plan to use bolt on types.Last edited by leafsprung; 07-11-2011, 07:27 PM. -
You weld a piece of tube between the inner and outer frame so it doesn't crush when you tighten up the bolts.Jason
