Soft Top Question
  • AU_88
    • Nov 2010
    • 135
    Soft Top Question
    I have a soft top and I have all of the hoop set in place except for the drain channels, which I don't have the right one. Does it matter if I run the top without the channels?
    Thanks,
    Robert
    WAR EAGLE!
    65 IIa 88
    95 RRC 25th Anniversary
    98 Discovery LE7
    00 DII (Sold)
  • jac04
    • 1884
    Sure, I suppose you could temporarily while you are waiting for parts. The edges of the top that are supposed to tuck behind the channels will flap around a bit at speed, especially the horizontal edges that tie off to the tabs on the upper channels. The upper channels connect the hoops to the windscreen frame, so the hoops may want to sway fore & aft a little. Also, the channels hold the weatherstripping for the door tops, so you will have major water leakage if it rains.
    • Jim-ME
      • 1379
      Speed? What's speed?
      Jim
        Jim
        Agreed Jim! And water leakage?! You're going to get that anyway!
