well he's back. Truck has run flawlessly since replacing alternator about 3 weeks ago in NC. Well today some old issues raised their head again. First went to start truck, turned over would not fire. Has not done this for about a month. I poured a little gas in carb it fired and started. Drove to work, shut it off, started fine. Drove about 1.5 hrs to a job site, stopped and got gas on way started fine. While at site had to move the truck, it started drove about 50yds, it stalled and would not start. A little fuel, took 2 times this time, ran fine. stayed about another hour and went to start it no go. Took many times to get it going this time. Once it starts it runs great! Things I have worked on/replaced in last month, New plugs,points condensed, cap,rotor, wires, fuel pump.
One other item. After I was on the road for about an hour my turn signals stopped working. They started working again when I started home, quit again for a while after driving for a while, then worked again. Not sure if it's related. This one has me stumped. I'm thinking it could be electrical but what is the fuel doing to make it run if so? Any thoughts?
) when a pump is starting to fail, it will not pump at slow speeds but at a faster speed it will pump enough to mask any problems. May be wrong, but I've seen this scenario before. Keep plugging away, you'll find it, after all it's only a machine.
Anyhow, I (and quite a few other people here) would be interested in your 2.25 fuel injection set-up. Feel free to start another thread on the subject.
