Vapor lock.....
  • knac1234
    • Nov 2010
    • 442
    Vapor lock.....
    Hello all,
    So I ventured down to Colorado Springs in the Rover as I had a dentist appointment and my wife thought that the Rover would make a good shrub-moving vehicle
    Did about 100 miles today and ran flawlessly, but for what I believe to be vapor lock. Very hot day--one of the hottest I have driven in since owning the truck---and high altitude still (6K ft++). After parking and coming back to the truck, I would have to raise the hood and let it sit for 20 min or so before it fired back up. Keep in mind, that the car starts first turn of the key, or worst-case second turn, always.
    So, I am thinking vapor lock.
    What can I do to reduce the effects. Some thoughts of mine--please add or comment:
    -The fuel line is currently run where it was when I bought the truck..rubber line from the pump, slung over the valve cover, to the carb (Weber 34ICH). This cannot be the proper routing....any ideas (cooler place)?
    -Some guy came up to try to help, and told me to use a metal fuel line instead as it would transfer heat away more quickly??? (that seemed odd as I thought it would attract heat)
    -I have an insulating block between the carb and the intake manifold presumably to help with heat. But let's face it, the intake is sitting on top of the exhaust manifold. Should there be a heat shield around the carb? If so, is a stock one available and will it fit the Weber? Does it even work/help???
    -Electric fuel pump---I have a new Napa electric fuel pump that I kept as a backup for my MGB SU pump. Thought about installing it as an inline backup to the mechanical. If experiencing vapor lock, and I were to turn on the electric pump, would that get me started?
    Not like I was stranded.....just delayed!
    Cheers,
    Julian
    Julian
    72 Series III NAS
    03 Disco
    65 MGB / 73 MGBGT
    71 RHD Hillman Super Imp
  • albersj51
    • May 2010
    • 687
    Julian,
    Been there and it sucks! someone on here recommended a low pressure e-pump and pre carb fuel filter with a bypass so you can run a return line to the tank. It wasn't recommended that you run the e-pump through the mech pump due to the risk of a mech pump issue allowing fuel into the oil.
    a british mechanic also recommended I make sure the carb float is adjusted propely.
    PM me if you need details on the e-pump/bypass filter.
    • LaneRover
      • 1743
      Your fuel line placement sounds almost correct. Is it held in place by a clip that is on the first valve cover nut?
      An old trick to get you home is to slice a potato in half and tie that around the fuel line - for future use since you are already home. On one drive through Sonoma Valley on a REALLY hot day with lots of road construction I wedged a 2x4 under the hood to keep the hood open a bit and create more room for the heat to escape. BUT that is a bit drastic . . .
      If it continues to be a problem I would even look at a bit of pipe insulation around the fuel line where it gets the warmest.
      • smukai
        • 75
        I live in Colorado as well. I used to have the same problem.
        I now run an electric fuel pump (no return line though...twin tanks so I'm not sure how I could handle a return line).
        I also do my best to run gas without ethanol. To me, it seems like ethanol lowers the boiling point of fuel and gets me into vapor lock trouble.
        This link has been helpful in finding clear gas: http://pure-gas.org/
        If you are ever in Golden, lemme know!
        Seth
        '67 IIa 109 Station Wagon (the daughter's toy)
        2003 XC70 (for the dog)
        2006 XC70 (for the wife/daughter/son)
        2002 650 Dakar (for trip planning purposes)
        • knac1234
          • Nov 2010
          • 442
          Jason & LaneRover-
          Thanks.
          I am surprised to hear that this is the proper routing (no clip holding it to the valve cover.....zip tied to the air intake hose!!). I would have thought that perhaps closer to the radiator (grille side) with air flow coming through directly over it?
          Fuel pump--I will have to explore that more. I had not heard about the fuel in oil issue. I had thought that if the mechanical pump failed completely, I could simply flip a switch to activate the electrical. In the event of vapor lock, I thought the same thing.....flip it on for a few moments to get it started and then shut it off.
          Float--Good tip, however I know mine is good from setting up for altitude a short while back.
          Cheers,
          Julian
          Julian
          72 Series III NAS
          03 Disco
          65 MGB / 73 MGBGT
          • albersj51
            • May 2010
            • 687
            IIRC, the issue with fuel in the oil is if the the diaphragm in the mechanical pump ruptures/fails, it could allow fuel to be pumped into the block diluting the oil and could result in a spun bearing. That was enough for me to avoid it. if you have a new pump or a recently rebuilt one, the probability of it happening is probably low. Also, your plan is to switch it on and only use it to start during VL issues (push the vapor out), its probably a none issue. In fact, I like this idea!
            For the return line I took the blanking plate on the tank, tapped it for a fitting and and ran some cheap fuel hose to it.
            • knac1234
              • Nov 2010
              • 442
              Jason,
              Glad you like the idea!
              Again, the electric pump would also serve as a backup to get me home if the mechanical died, and then I would immediately replace the mech pump to reduce the chance of the issues you mention. In the center of my gauges on the S3 there is a blanking plate where I believe a diesel related light went. Was thinking of installing a lighted round push button switch for the pump there. Right in front of my face and lit up to remind me it is on....and not have to cut or drill any extra dash holes!
              Can you elaborate on the return line? Currently I have an emissions controlled Series III that is no longer emissions controlled! I think the line runs from the tank to the pump to the Weber. There is a line that vents the tank under the truck (which if you overfill the tank, the fuel comes out of). PO change.....never messed with it.
              Julian
              Julian
              72 Series III NAS
              03 Disco
              65 MGB / 73 MGBGT
              • rickv100
                • Aug 2010
                • 143
                Why not insulate the line with some reflective foil covering? Seems like the simple solutions is the best.
                Ad hoc solutions I have heard include spraying the fuel pump with a fire extinguisher to cool it down.
                Rick
                73 xMOD S3 109
                52 M37
                • daveb
                  • 513
                  This thread contains false information. The factory fuel line routing goes in front of the valve cover and thermostat housing. It gets held down by a metal p-clip and one of the three thermostat housing bolts. Routed over the valve cover in the way suggested here is what I call the "Vapor Lock Special"
                  • knac1234
                    • Nov 2010
                    • 442
                    daveb--thanks for the insight. Do you or anyone else have a pic of exactly how that is routed then?
                    Julian
                    Julian
                    72 Series III NAS
                    03 Disco
                    65 MGB / 73 MGBGT
                    • meatblanket
                      • Dec 2007
                      • 98
                      Originally posted by knac1234
                      Jason,
                      Vapor lock is brutal in CO. The only really effective way to deal with it is to fit an electric pump. I had a setup just like this on my IIa.
                      However, if you plumb them in a series, I don't think the mechanical pump is strong enough to pull the fuel out of the tank and through the electric pump. So to use the electric pump as an auxiliary, you have a line that goes around the electric pump that includes a one way valve. Carter makes a setup to accomplish exactly what you want to do, and it works well. I posted part numbers on the old GnR site.
                      Having said that, if I were doing it again, I probably wouldn't bother keeping the mechanical pump.
                      '55 SI 86
                      • artpeck
                        • Dec 2009
                        • 368
                        I can post a photo later today of my routing with is stock factory if that is still helpful.
                        • tmckeon88
                          • 141
                          I had a vapor lock on hot days issue a few years ago and what I ended up doing was drilling two or three small holes in the inside of the gas tank filler cap. Not all the way through, but just through the inner sheet metal, to allow air to pass more easily into the fuel tank as it emptied. For whatever reason, it was not vented enough. It ran fine after that. If you get stuck again, you might just try opening the gas cap for a moment to allow air in, then starting it. If you hear some hissing as if you're releasing vacuum, that might well be part of the problem. I am not sure about how the high altitude affects the whole situation. For what it's worth, my fuel line runs in front of the valve cover too, rather than on the top of it.
                          Good luck!
                          Tom
                          Tom
                          1969 Series IIA 88"
                          • meatblanket
                            • Dec 2007
                            • 98
                            Higher altitude = lower atmospheric pressure which lowers the boiling point of your fuel. So the higher you are, the less heat it takes to cause a problem. I could drive my truck around Denver with no problems, but then vapor lock at 10,000 ft (prior to installing the electric pump).
                            '55 SI 86
                            • knac1234
                              • Nov 2010
                              • 442
                              All-
                              Thanks for the comments.
                              Tom-Good idea.....actually when at a stop at Walmart, the mechanic suggested that one....slight pressure release, but the vent on the tank is an overflow line (like my Hillman Imp)....might help.
                              Meat-Electric is sounding better, especially as I have a new pump lying about.....I live at 9100 feet, but between there and Co Springs it's a 3000 ft drop....still high though.
                              Artpeck-Please do post a photo....that will be the first try.....just buy a longer bit of fuel line and run it as yours shows.
                              Carb shield.....any thoughts......was there one stock an a S3....fits my Weber.....any use?
                              You know the more thought I've given to this.......the only other car I've experienced this with up here is my Imp. Coincidentally, it is the only other car I have with a mechanical fuel pump. Hmmm.....
                              Cheers,
                              Julian
                              Julian
                              72 Series III NAS
                              03 Disco
                              65 MGB / 73 MGBGT
