Fuse Question.
  • TedW
    • 887
    Fuse Question.
    Is there a Buss or equivalent substitute for the Lucas 17A continuous/35A Blow fuse?
    I have a short somewhere and am blowing fuses like mad. Gotta buy in bulk until I find the problem - think its my backup lights. Had everything taken off for a repaint and now have the short after hooking stuff back up. Everything else lights up - just no backup lights.
    Thanks in advance - Ted
  • bkreutz
    • Apr 2010
    • 408
    What I do to diagnose things like this is remove the fuse, hook one lead of an ohmmeter to the fuseholder and the other lead to a ground. A dead short will show up as continuity, then I poke around until the continuity goes away(I've found the short). Lot cheaper than replacing a bunch of fuses.
    Gale Breitkreutz
    '03 Disco
    '47 CJ2A
    • Billy5
      • Aug 2010
      • 172
      As someone who is going through an electrical whirlwind, ( though getting to the end of it), I would not under any circumstances put a larger fuse than what is specified. 35 amp is a rather big fuse to start with. I am replacing mine ( in the near future) with a marine grade, enclosed fuse/ power distribution bar, with inline fuses on the constant hot leads. Labeled of course. According to my diagram for a 1969 series US Federal Standard Negative Earth ( this made a big difference by the way), there is a back up light switch#38. This could be an issue.
      1969 Series 2a Bugeye
        • TedW
          • 887
          Thanks to all responders for help and advice.
          Ted
          • Lord Icon
            • Jul 2008
            • 176
            Upgrade!!!
            My unimog had breakers. It was the best idea I have ever seen for an off road truck. I have found that boat and marine shops sell re set able breakers in almost any size . Never have to replace a fuse again.
            Whence came you my brother ? From the East....
            • Billy5
              • Aug 2010
              • 172
              I work in a marina. They do come in all sizes. Quite handy. When they pop, a little lever pops down. All you have to do is push back up in place to reset. I am considering these on my 2a. They dont take a lot of room. We use them all over on a boat. Pricey, yes, but like you said never have to change a fuse again, and get the same if not better, protection.
              • TedW
                • 887
                Figured out why my fuses were blowing.
                Dumba$$ move on my part. Had reverse lights plugged in backwards.
                • LaneRover
                  • 1743
                  DOH!
                  • TedW
                    • 887
                    Originally posted by LaneRover
                    DOH!
                    That's MISTER DOH to you, buddy.
