What diameter and thread pitch are Series 3 wheel studs? I want to replace my screw in IIA type with some that are slightly larger (the press in type). I think I am right that the III's are larger.
Series III Wheel Stud Thread?
67 IIA 109" NADA Wagon (sold)
-I used to know everything there was to know about Land Rovers; then I joined the RN Bulletin Board.Tags: None -
If you buy the SIII studs you can dremel away the threads on the SII setup and then press in the SIII studs. Did this years ago on my SII 109 and it worked a charm. -
Ser II to Ser III Hub studs
Do not forget to drill out the brake drums also !Les Parker
I know that other stuff, what I need to know is are the threads English or Metric, what size and what threads per inch, or thread pitch if they are metric.61 II 109" Pickup (Restomod, 350 small block, TR4050)
So, are you going to make your own?
The Series III Stud # is RNC501 Stud or use the late IIa stud PLC405 and you will not need to change the lug nuts.Les Parker
Les, ya killin me dawg. English or metric, diameter and pitch please.
The thread is not listed in your catalog.61 II 109" Pickup (Restomod, 350 small block, TR4050)
5/8" - 18
Finally found it.
Was that so hard?61 II 109" Pickup (Restomod, 350 small block, TR4050)
Not difficult at all, just want to know where you'll get the studs from, also the length etc. You know, minor details like that.Les Parker
More info to follow, working on a special project.61 II 109" Pickup (Restomod, 350 small block, TR4050)
Les, that was really low. Letting me go all this time thinking it was 5/8 - 18. I even ordered the stupid bolts for a test! All the time, knowing it was 16mm x 1.5.
I found the correct info on TeriAnn's site.61 II 109" Pickup (Restomod, 350 small block, TR4050)
