Brake adjusters-orientation
  • kwd509
    • Aug 2010
    • 190
    This is likely a simple question, but I keep getting turned-around..... As i prepare to rebuild the rear seals, hubs, bearings and brakes, I have most everything ready to go on. But, I have seen no place that definitively addresses the orientation of the snail cam brake adjuster. I ASSUME that they should be oriented consistently so that a clockwise turn of the adjusting bolt results in tightening the shoes against the drum. But this results in two questions:
    1- is that assumption correct?
    2- does it matter from a mechanical standpoint?
    Hopefully, this is the biggest issue I face as I replace the stub axle distance piece, inner seal, bearings, brakes and drive member components. After really focusing on cleaning up rust and grime, this is finally the first rebuild/renewal step. The road seems long but it is exciting to finally be making a small but definitive move toward a working vehicle.
  • jac04
    • 1884
    Well, from my experience, the adjusters are not always CW to tighten.
    On my 63 (10" brakes all around), they were CW to tighten on the LH side and CCW to tighten on the RH side.
    On my Lightweight 11" front brakes, the front adjusters are all CW to tighten.
    These were all factory-installed adjusters.
