HELP STRANDED IN WESTPORT CONN SERIES 2a
  • englandseries
    • May 2011
    • 37
    Anyone close to westport conn new owner is on way back in a 1971 series 2a 109 and has broken down need some roadside help!
    i am on computer to see so let me know
    Thanks
    greg
    Not close, but what happened, mechanically speaking?
    • singingcamel
      • 398
      Whats the problem?
      • englandseries
        • May 2011
        • 37
        New owner says truck turns over but will not run, i had him replace fuel filter(truck is getting fuel) and the truck has had new points condenser and cap wires and plugs just installed last week so perplexed any suggestions?
        Thanks
        • daveb
          • 513
          make sure all the plug wires are tight. check the didtributor cap and rotor are properly seated and the point and their wiring are all correct and making good contact. if they have a smartphone they can send you pics and you can upload them here for us to peruse.
          • englandseries
            • May 2011
            • 37
            thanks everyone new owner is going to rent a u haul and tow rover home
            • yank
              • Nov 2007
              • 191
              You could try these guy's
              Next town over.
              328 Commerce Drive
              Fairfield, CT 06825
              203-371-8579
              classic4x4s
              72 SIII
              • Ncrover725
                • Jun 2011
                • 259
                Staying in the fight
                The truck is getting fuel right now with no issues. I checked under the cap and the condenser screw was very loose. Snugged up that some then I got a burning smell. I am getting the rover to land rover Milford for a quick look / advice. I started the drive so I think I am going to stick with it until I have to be at work Monday.
                1971 Ex Mod IIA 109
                1985 D110
                1998 D1 (Sold)
                • yank
                  • Nov 2007
                  • 191
                  If its not to late you mite want t give classic 4x4 a call. I don't know much about them but they do work on series trucks. I doubt LR of Milford has.
                  72 SIII
                  • Les Parker
                    • May 2006
                    • 2020
                    Roadside assistance
                    Ask for Dawson tel # (203) 371-8579 or (203) 870-1022.
                    Good to know that the fuel system is OK.
                    Keep us info'd.
                    • LaneRover
                      • 1743
                      I would check all the different ignition related connections.
                      Plug wires, low tension lead, power to coil etc . . .
                      • LaneRover
                        • 1743
                        • I Leak Oil
                          • 1796
                          Check to see if you're getting spark at the plugs......
                          If you have that and you have fuel then you probably have bigger problems. Or I should say your friend has bigger problems.
                          • englandseries
                            • May 2011
                            • 37
                            bobby,
                            spoke to carey that screw also is the adjustment screw for points so your points are "tango uniform" re-set points and should run ......
                            • Ncrover725
                              • Jun 2011
                              • 259
                              Norwalk, CT
                              The truck made it to Norwalk, CT and we are down again. I tried classic 4x4 and no one has picked up the phone all day. Any one know of any one in the area with parts or a shop?
                              Bobby
                              910-568-6217
                              1971 Ex Mod IIA 109
                              1985 D110
                              1998 D1 (Sold)
