building a roof rack
  • Skookumchuck
    • Oct 2010
    • 269
    Has anyone here built a roof rack? what did you use aluminum or steel? I am wanting to build one any info is appreciated
    1968 Series IIA
    1987 D90 Kid's project
    German wirehair Pointer (Wood Hound)
  • Terrys
    • May 2007
    • 1382
    You can buy 1/2" box tubing and copy a Brownchurch pretty easily. Got a galvanizer near to you out there?
      If you can work the aluminum and afford it that would be the better option. It'll keep the weight down and you won't have to finish it with anything. But as Terrys mentioned, square steel tubing is cheap and easy to work with.
      • 73series88
        • Oct 2009
        • 587
        i dont have the skill or patience
        AARON
        67 series 2a 88 RHD sold
        88 RRC sold
        60 mga coupe
        • Jim-ME
          • 1379
          SafeAirOne makes a really nice modular aluminum rack if you don't want to build one yourself.
          Jim
          • mongoswede
            • May 2010
            • 757
            You could build one using a welder to glue all the joints together or you could bolt everything together...all depends on what you have to work with and skills. I have seen people make roof racks out of wood, plumbing fittings, steel, aluminum, etc. If you are looking to make a gear basket style rack you could easily make the basket and then just buy a rain gutter foot kit and cross bars from Thule and just clamp your construction in place.
            • Broadstone
              • Jan 2009
              • 216
              Just last week I finally built a set of roof bars. Purchased the tube steel for around $40 and took about 3 hours to fabricate. I like roof racks, but feel roof bars are more suitable for me. They are moveable depending on what you are carrying, very light weight,, and quick to remove when you don't need them, which for me is most of the time. Plus they are not wheel base specific for 88,109,90,110. I cannot fit in my garage with them and they remove in 5 mins without recruiting someone to help you as the case with a roof rack. I get a lot of satisfaction out of fabrication so little projects like this I find quit fun.
              I strapped on a safari top and brought it to another board member just last night. Works great!
              1973 NADA 88
                Jim
                Thanks, Jim.
                Broadstone, I see you've taken the tropical roof/sun sheet concept to a whole new level!
                • Broadstone
                  • Jan 2009
                  • 216
                  Keeps the truck twice as cool right, isnt that what they are for??
                  1973 NADA 88
                  • HybridIIA
                    • 98
                    I think I did something wrong . You're double roof setup looks much more effective than mine.
                    '62 109 - coil sprung
                    '64 88 - coil sprung
                    • mongoswede
                      • May 2010
                      • 757
                      its pictures like this that make me want to keep my 109...no not whats on the roof rack.
                      • Skookumchuck
                        • Oct 2010
                        • 269
                        I have access to welders and should be able to fab something together. What I need detalied pictures is the attachment point to the rain gutters and how they are held in place. The rest is pretty straight forward. Any pictures of that detail would be helpfull. There is a galvanizing place in Calgary and Lethbridge so I should be able to get parts coated or I could just powder coat them as well.
                        1968 Series IIA
                        • siii8873
                          • 1013
                          not sure what you are looking for, but thule makes a rack system that fits a rover roof
                          THING 1 - 1973 88 SIII - SOLD
                          THING 5 - 1958 109 PU
                          THING 6 - 1954 86" HT
                          • HybridIIA
                            • 98
                            Here is how mine is attached. I can email more photos to you if you of the rack if you need.
                            • Skookumchuck
                              • Oct 2010
                              • 269
                              that looks good, thanks do you have the measurements for the cross members? and how many cross members shoud I use?
                              1968 Series IIA
