Parts for general maintenance
  • doctorspears
    • Aug 2011
    • 6
    Hi all,
    I'm happy to say I just bought my first Landy, which should be arriving on Monday. It is a 1979 series III exMOD 109. As I do with all "new" vehicles I like to change the oil, oil filter, air filter and the usual other fluids. Can anyone provide some part numbers or recommendations for maintenance? I'm looking for:
    - Oil filter manufacturer/part#
    - oil recommendations (20w50?)
    - air filter part#
    - fuel filter?
    - other maintenance I should do?
    Thanks!
  • disco2hse
    • Jul 2010
    • 451
    This should get you started:
    Alan
    109 Stage 1 V8 ex-army FFR
    2005 Disco 2 HSE
    • stonefox
      • Jul 2010
      • 450
      Doc,
      Its very handy to have a green bible and parts book.
      Good luck with your new truck.
      Have fun!
      Sean
      1963 88'' IIa daily driver
      1970 88"
      1971 88"
      authenticstoneworks.com
      • LaneRover
        • 1743
        First I'd ask yourself some questions about your Rover.
        Did it sit for awhile before you bought it?
        Was the previous owner good about the maintenance?
        The transmission, transfer case, differentials and front hubs probably should be at least checked but possibly having the 90wt gear oil changed - if you change the gear oil you need the copper crush washers to properly re-seal the drain and fill plugs.
        Unless it has been changed the air filter is an oil bath filter which can be cleaned out and have its oil changed.
        How is the coolant?
        How is the electrical system? ie do all the lights work properly?
        Basically just check the vehicle over. I am not trying to scare you with a huge list of stuff to do, but giving the vehicle a good once over will help you learn your vehicle and notice when something isn't right.
        Welcome to Rovering!
        Brent
        • doctorspears
          • Aug 2011
          • 6
          Thanks All!
          • 73series88
            • Oct 2009
            • 587
            Welcome
            All the help you would ever need is here as well. if you take care of your rover. It'll take care of you .
            Aaron
            67 series 2a 88 RHD sold
            88 RRC sold
            60 mga coupe
            • doctorspears
              • Aug 2011
              • 6
              So my rover finally arrived this morning and it looks pretty neglected. I'd say its been sitting in a field for the last two years (especially considering it had a birds nest in it). I'm going to give her an oil, fuel filter and diff fluid change later this week. But in the mean time I have two concern perhaps you guys can help me with.
              (1) It doesn't brake well at all. There are no grinding sounds or anything like that, but there is almost no stopping power. I'm guessing the first thing to do is bleed the brakes? But i'm not sure how to do that.
              (2) There are a few small oil leaks. One appears to be dripping from the seal on the oil pan, the others are from the front left and right wheel area (its dripping down the inside of the tire to the ground).
              - for the oil pan, what should I reseal with? RTV?
              - for the leaks on the wheels, any thoughts?
              Thanks in advance!
              • LaneRover
                • 1743
                Thanks in advance!
                The brakes have bleed nipples at each wheel. Before you round them off with a wrench (been there done that) I would spray penetrating oil on each one over a day or two and then loosen the nipples first using a socket that grips on all sides. I would look up brake bleeding on youtube and there are probably a bunch of videos you can watch. Doing it the old fashion way requires a helper to press the brake pedal and hold it while you release the bleed nipple and then you need to re-tighten the nipple before they let up on the brake pedal. Every so often get up of the ground and make sure there is enough brake fluid in the reservoir or you will need to start from the beginning again.
                On #2 is the leak coming from the hub or from between the brake backing plate and the brake drum? If it is leaking from in between the brake backing plate and the drum then it may be brake fluid and thus the cause of your problems. Do the brakes firm up after a pump or is it losing fluid? If it firms up after a pump the brakes are way out of adjustment or have air in the system.
                I would worry about the brakes first. You can re-seal the oil pan I recommend getting the cardboard seal and then putting the insta-gasket stuff on that.
                Have fun!!
                • knac1234
                  • Nov 2010
                  • 442
                  As a newbie somewhat myself, on the oil dripping down the wheels, I am going to guess your swivel ball seals. Cheap to replace (I think I paid $5 a seal or so) and took me all of 2 hours max!
                  The rest of the leaks....I live with em and watch the levels religiously!
                  Brakes....I'd look everything over. One system that should be right for sure!
                  Regards,
                  Julian
                  Julian
                  72 Series III NAS
                  03 Disco
                  65 MGB / 73 MGBGT
                  71 RHD Hillman Super Imp
                  • Jim-ME
                    • 1379
                    The leaks on the wheels are probably the swivel seals. Not the easiest job but far from the worst. I tend to use both gaskets and RTV. I'm sure that others will chime in on which is best. Try adjusting your brakes before you bleed them. I am not familiar with 109 brakes so I'm sure others can give you the specifics on adjusting and bleeding them. Before you go too far I'd urge you to get a shop manual either in book form or CD form. They are invaluable. Post some pics of your Rover when you get a chance.
                    Jim
                      Jim, you forgot to mention a spare fan belt....
                      • Jim-ME
                        • 1379
                        Go ahead rub it in.
                        Jim
                          Any time buddy! That's what friends are for!
                          • Jim-ME
                            • 1379
                            You'll get a real laugh when I have to drive a Yaris to Metal Dash this year.
                            Jim
                            • doctorspears
                              • Aug 2011
                              • 6
                              Thanks for the help. I fixed a few leaking seals in the transfer box (which had NO fluid in it) and the oil pan. This morning I decided to tackle the "leak" from the driver's side front wheel. It turns out to be Brake fluid, not oil. Specifically the wheel cylinder is leaking. I'm going to try and tear it apart to determine if it is truly broken or can be repaired. However, is there some trick to removing these brake shoes? It seems like i'm going to damage the spring if I pull to hard.
                              I attached a picture of the brake area and a quick pick of the Rover :-)
