SIII Dome light ground
  • crankin
    • Jul 2008
    • 696
    After three years I am hooking back the dome light...so, where do you ground it?
    Birmabright Brotherhood
    Clint Rankin - 1972 SIII SWB
  • martindktm
    • Jun 2008
    • 218
    On mine its grounded only by the screws that fix it to the top...
      Grounding it with the mounting screw is also known as the Lucas Hi\low beam interior lighting system. Mine also comes with an occasional "flicker" mode...
      • TedW
        • 887
        Clint:
        IIRC it grounds to the mounting plate, as stated above.
        Use a lil' dab of dielectric grease with all grounding screws - I find that it keeps a good connection and also keeps corrosion to a minimum.
        • crankin
          • Jul 2008
          • 696
          OK. Thanks everyone.
