hello to all...I'm having clutch problems and would appreciate any input. I searched various rover sites which have been helpful however, I am now stumped.
vehicle:
83 SIII ex-mod 24v FFR 5-bearing engine petrol
problem:
hard shifting eventually no shifting at all. start in neutral and jam it into either 1st or 3rd to move or start in first and jam it into high range. sometimes the truck will lurch forward in neutral.
diagnosis:
clutch jutter due to rear oil seal leak, friction plate worn.
action:
cleaned up housing, replaced clutch friction plate, pressure plate, bushing, throw-out bearing w/collar, plastic staple, push rod retainer (all recommended replacements). here is a pic of the worn plate. the loose springs were jingling in the flywheel housing. not a huge amount of oil contamination, flywheel housing dirty with oil gunk. scary for sure! replaced rear oil and cork t seals.
decided to replace hydraulics, master, flex, slave. tested master by carefully crimping the flex hose at the master. the result was a hard pedal...no movement...good to go. no leaks in any of the lines or at slave. all hydraulics test good to go.
The problem still persists. Now for speculation:
Is the friction plate not releasing from the flywheel thereby not allowing the vehicle to properly shift gears? If so, even with proper hydraulics, is the push rod not depressing enough to disengage the flywheel? The clutch pedal seems to be doing its job. here is a vid of the clutch being depressed as viewed through the bell housing window
View My Video
any help is appreciated!
vehicle:
problem:
diagnosis:
action:
View My Video
