Convert IIA pickup to hardtop?
  • tryanindy
    • Sep 2011
    • 4
    Is it possible to convert a IIA pickup to a hardtop? If so, would you just need to remove the pickup's rear window unit and tailgate, and then replace with an 88" hardtop?
    Thanks in advance!
    --Tim
    For the most part. You'd need to find an upper rear door or install a lower hinge to use a full rear door.
    • LaneRover
      • 1743
      Exactly. If you don't want to keep the p-up top you could sell that to get the bits for the hardtop. But p-up tops tend to be a bit rarer just so you know.
      As does the 'liftgate' that is needed to work with the tailgate.
      Brent
        Originally posted by LaneRover
        As does the 'liftgate' that is needed ...
        That's the word I was looking for--liftgate!
        • rwollschlager
          • Sep 2007
          • 583
          all that being said are you interesting in parting with your pickup top?
          Where are you located?
          thanks!
          -Rob
          72 SIII 88
          67 SIIA 109
          82 SIII Stage 1 V8
          • 73series88
            • Oct 2009
            • 587
            i'll buy it
            aaron
            67 series 2a 88 RHD sold
            88 RRC sold
            60 mga coupe
            • tryanindy
              • Sep 2011
              • 4
              Thanks all for the quick responses. I'm thinking about buying a pickup and wanted to know my options for conversion. If I end up with an extra p-up top, I'll post here first!
              • Winemark
                • Feb 2010
                • 83
                If you dont already own the pick up why dont you just buy a regular Series hardtop rather than convert? Is this just to see if you could do it?
                Best,
                Mark
                __________________
                1965 Series IIa
                • LaneRover
                  • 1743
                  As you can see from the responses the p-up tops are a bit rare. Having the various tops is pretty cool. I have a 109 p-up that has the p-up top, a full canvas as well as the 3/4 canvas for use with the p-up. It is pretty cool to be able to switch them back and forth.
                  • ducttape
                    • 169
                    I have an 88 hard top I am looking to sell. In NY. Probably enjoy a p/u but I enjoy the soft top too much now.
                    1967 Series IIA 88
