Love things in wood crates
  • Broadstone
    • Jan 2009
    • 216
    #16
    Originally posted by rejeep
    engines are sold in the states and North America by our hosts and others..
    I guess it all just depends on what you want and where you are going to get it from..
    Is there any advantage to purchasing turners complete unit. Would rebuilding your own block and purchasing only the high performance head be a cheaper option?
    1973 NADA 88
    • rejeep
      • Apr 2010
      • 420
      #17
      im sure any good machine shop can rebuild one of these motors..
      but doing a cost comparison, time, effort and energy flow graph along with a whole lot of I dont care thrown in the mix I decided to buy the complete unit.
      I wont have a lot of down time that I really cant afford. (time is worth more than $$$ to me) and at the end of the day I have a spare engine I can do with what I please..
      deff not for everybody, but for me the drop in reman was a no brainer..
      1971 SIIa 88" NAS Dauntles V6
      1974 SIII 109" RHD
      • rejeep
        • Apr 2010
        • 420
        #18
        Originally posted by rwollschlager
        are there any break in procedures? or drop in and go?
        -Rob
        came with 2 jugs of break in 30 wt oil and a simple line in the booklet that said basically no idling or heavy load on the engine.
        Ill run it DD duty from now till it put it away for the winter.. change the oil and be ready for whatever the spring throws at me.
        1974 SIII 109" RHD
        • jac04
          • 1884
          #19
          There is a break in procedure that calls for the engine to be brought up to operating temperature, then re-torque the head bolts (IIRC, while the engine is still warm, but double-check that) and re-set valve clearance. They also want you to vary engine speed - don't cruise at a certain rpm for a long period of time. Then change the oil at 500 miles and break-in is complete.
          • rejeep
            • Apr 2010
            • 420
            #20
            just noticed something about my new engine vs. my old engine..
            my old engine has the oil fill in the valve cover..
            my reman has the side tube..
            I'm not opposed to swapping, but are the tubes available?
            1974 SIII 109" RHD
            • Terrys
              • May 2007
              • 1382
              #21
              It may not be right, but I was always under the impression the oil fill in the valve cover change went when they went to the 5 main bearing engine.
              • Jim-ME
                • 1379
                #22
                Talk to Matt Browne (junkyddogII) as he has my old 2.25 engine which had the tube fill or talk to Sean (stonefox) as he might have one as well.
                Jim
                • rejeep
                  • Apr 2010
                  • 420
                  #23
                  any way to visually tell what motor I have in there now to to eliminate that though?
                  1974 SIII 109" RHD
                  • LaneRover
                    • 1743
                    #24
                    You could always clean up and put on your old valve cover (just ask turner for another sticker/plate) to put on it.
                    • rejeep
                      • Apr 2010
                      • 420
                      #25
                      I was thinking that as a backup, or calling them and asking them what to do in this situation..
                      1974 SIII 109" RHD
                      • jac04
                        • 1884
                        #26
                        I found that Turner was very responsive to my questions submitted via e-mail. I would verify what they want you to do since the engine is under warranty.
                        • TedW
                          • 887
                          #27
                          Why do you want the side filler tube? Just curious. The way you have it now is a lot cleaner IMO - less stuff in the engine bay. I have a IIA and can now bleed my clutch slave through the engine bay.
                          I switched to the valve cover w/cap when my new engine was built, and drilled / tapped the filler tube cover for a vent tube, so the engine is still vented from the head and the block.
                          • ThorH
                            • May 2011
                            • 53
                            #28
                            I just got my engine out today, finally. Going to tear it all down this weekend, and planned on dropping it off a the machine shop Monday.
                            If you don't mind, what did the Turner cost, delivered? Want to weigh that option before I commit to the machine work.
                            Thanks!
                            1973 SIII RHD 2.25 Petrol
                            1992 RRC Hunter
