Sand ladders
  • Lord Icon
    • Jul 2008
    • 176
    Sand ladders
    Our hosts have on offer a set of Brit aluminum sand ladders. I bought a set for my last rover from them, used quite often but I sent them with the truck when it was sold....
    Having said that. My new rover project is in need of a set as well. I have encountered a source of US Army spec steel ladders WWII issue , all other specs being the same , just steel alloy instead of light aluminum. The price is 1/3 of the aluminum ones but 2 times the weight. ( about 65 lbs for a pair of 5 footers.)
    Anyone have any thoughts?
    Whence came you my brother ? From the East....
  • luckyjoe
    • 335
    Yeah, forget it. Try an organize a group-buy of 4x8 sheets of GRP grid. You can then cut them to your desired length/width and have a nice durable, non-rusting set at a fraction of retail. You'd have to do a little work though...
    Tom P.
    1965 exMoD 109
    1995 RRC LWB w/EAS
      I suspect that you probably won't get a whole lot of use out of them where you are located, so either one would be the same. Bridging ladders, maybe.
      GRP grid can be used in both roles, however.
      • Lord Icon
        • Jul 2008
        • 176
        errr...
        The rust thing is not of concern. They have been stored out in the weather for 50 years in stacks and have a nice patina on them but still no rust yet. These were designed for landing mat in the Pacific, salt air and all. As for use, I could have used them at the winter romp. The mud hole that ate the axle off the Jeep in front of me could have used them as well.
        • Skookumchuck
          • Oct 2010
          • 269
          You also have to admit they do look good on the roof rack
          1968 Series IIA
          1987 D90 Kid's project
          German wirehair Pointer (Wood Hound)
          • Triumphdaytona2007
            • Aug 2010
            • 87
            i have both the steel and the aluminum mats i keep the aluminum on the truck, i like them better, the steel just seems too heavy to mess with but i found them for $10 at a flea market the aluminum ramps were 150 from tlr
            1964 Series IIa 109" Pick-Up RHD
            1965 Series IIa 88" Wagon LHD
            1968 Series IIa 109" Station Wagon LHD
            • Rat Patrol
              • 162
              Why not fabricate a mounting system to use the ladders as the rear bench?
              1973 Series III 88. "PHYDXO"
              • Andrew IIA
                • Feb 2008
                • 327
                Man, sand ladders would look cool on my roof rack........... I like cool. I drive on soft sand ALL the time (for good and ill) and haven't had a need for sand ladders since.. ever. I'd like some alum bridging ladders though, they'd look cool too.
                Andrew
                '63 SIIA 88" SW
