Series Gearbox questions
  • slorocco
    • 208
    I purchased a replacement used gearbox for my series III 88" and started the swap this weeknd but ran into a snag. The gearbox/t-case came out of a Series III 109 with a 6cyl. Apparently the bell housings are different. The holes in the bellhousing are not in the right place to bolt up to the motor. So, heres my question. Are there any other differences I need to know about? Can I simply swap bell housings and bolt it in or are there other differences that would cause a problem?
    Yes, swap bellhousings and you'll be all set (providing the clutch actuators are the same type).
    • slorocco
      • 208
      Thanks Mark, the clutch slave cyl looks to be about the same, I'll double check that to make sure.
      Dan
        Dan
        It'd be obvious if it was the older style as it uses an inelegant frankenstien mechanism to actuate the clutch as opposed to the simple, clean slave cyilinder mounted to the bellhousing of the later style.
        • luckyjoe
          • 335
          Now-now Mark, you're just a bit sensitive after that ignition switch set screw...
          Tom P.
          1965 exMoD 109
          1995 RRC LWB w/EAS
            • slorocco
              • 208
              Ok, I got it. I'm familiar with both and this is definitely the later style. I thought you were referring to something else being different between the 4 cyl and 6 cyl versions.
