for the water pump and thermostat housing...whats the best sealer to use? assume Hylomar the whole way around?
gaskets and sealants
I personally just use the paper gaskets and Permatex High-Tack Gasket Sealant on one side for the water pump and just the paper gaskets alone on the thermostat housing.
I'm sure responses to the question will be as varied as the people who own Rovers.--Mark
I also use Permatex on all the gaskets, but I use the red, spray gasket adhesive. If the surface is really craggy or I can't get a satisfactory cleaning (hub fixings in situ, por ejemplo), I use YamaBond, which is essentially Hylomar that's cheaper and available locally.© 1974 Apis Mellifera. Few rights preserved.Comment
I cleaned up the surfaces and used Permatex Gasket Sealant with the paper gasket but I was still getting leaks around the thermostat housing, I pulled it apart and wound up using Hylomar. No leaks after using the Hylomar.
Permatex makes a similar product to Hylomar so I would go with that the next time.
Rick73 xMOD S3 109
52 M37Comment
