From time to time, and somethimes very very often, (as is the case with the gearbox/transfer case) the studs come right out when I try to remove the nut. This happened on the bell housing, pinion housing and now on the transfer case sump cover. I expect this to be a continuing pattern.
At first glance it would appear that I could simply screw them back in using the nut as a bolt head...... But does this allow me to get proper fit and torque.....? I write this knowing it may be a stupid question, but I submit this ready to accept advise and/or whatever else comes.
Thanks.
Thanks.
