I just finished fixing a clutch problem and as always there is something else to fix. I have a '74 109 exmod that is almost finished with its frame off restoration but the brakes do not work. They didnt work when I started the restoration but I thought it would get worked out as I was replacing everything.
The problem: I believe there are two separate problems that could possibly be linked together.
First, no matter what speed you are going as soon as you push the brake pedal down it goes straight to the floor and nothing happens. I have gone around the truck 4 times on each wheel bleeding them and there is zero air in the lines.
Second, With the rover off you can push the brake pedal down and it will stop about half way with good pedal but once you turn the rover on and push the pedal down it will go straight to the floor and will not come back up. It is like the servo is sucking the pedal to the floor and wont let it go. I have added extra/ stronger springs to the pedal but that has not helped at all.
Already replaced the following parts: new brake lines, new shoes, I had the drums turned, new servo, new master cylinder and all new adjusters on each wheel as well as all new wheel cylinders.
I am about to pull my hair out because there is nothing left to replace and I am out of ideas.
